Go Back   Automotive Forums .com Car Chat > Oldsmobile > Intrigue
Old 10-15-2007, 11:33 AM   #1
kababy
Lightbulb blinkers?!?
hey guys . . . real quick question.. my blinkers DO NOT WORK!! at all. i took it in to a garage & they said its my flasher module, which is supposed to be under my steering wheel, but i was on my knees 4 like 3 hours tryin to find it. they also said its weird bcuz my 4 ways works just fine, but the blinkers jus dont wanna work. i have searched ALL over the internet on how 2 replace the flasher module but im stuck any help would be awesome! thnks...
kababy is offline   Reply With Quote
Old 10-16-2007, 09:19 AM   #2
panzer dragoon
Re: blinkers?!?
panzer dragoon is offline   Reply With Quote
Old 10-17-2007, 01:29 PM   #3
remark123
Re: blinkers?!?
Like Panzerdragoon says, only I think you may have a problem with the turn signal switch instead. If the hazards work, then it is not the flasher. The flasher switch and the flasher are the same unit, electronic flasher as opposed to the old relay style most of us are used to. I had an impact damage to my column switch, turn signal, and had a similar problem with no turn signal, but hazards continued to work. Replaced turn signal switch, all is well. My .02 worth.
remark123 is offline   Reply With Quote
Old 10-17-2007, 01:58 PM   #4
kababy
Re: blinkers?!?
thnks guys i already got it taken apart, now im jus waiting to see if thats what it really is. appreciate it!
Old 10-18-2007, 03:58 PM   #5
panzer dragoon
Re: blinkers?!?
when my turn signals did not work and I had a bad flasher relay that was getting worse:
At first the turn signals would act up and go either fast or then slow or not at all. It got worse and then I had to toggle the flasher switch to get them to work (hit turn signal then hit the flasher switch on then off). Eventually I had to toggle the flasher switch many times to prime the system and then eventually even that didn't work.
