Go Back   Automotive Forums Car Chat > Ford > Windstar
Old 01-21-2009, 03:49 PM
yitzg yitzg is offline
'01 PATS key in steering column
So I only have one transponder key for my '01 Windstar and I'm not interested in paying $150+ for a second key. I got two (non-transponder) keys made that will open the doors and turn the ignition, but (obviously) not start the car. Trying something I've heard in the past, I unscrewed the bottom shroud under the ignition switch and was able to slip the PATS key into one spot where the engine would start with the non-PATS key, but it would be impossible to close the shroud with the PATS key in that spot. I could not get it to start in any other spot.
So here are my questions:
1) Is there a particular spot I should try?
2) Can I wrap some wire around the key and then connect the wire directly to the sensor?
3) Is this all a bad idea?
Thanks for your help,
-yitzg
Old 01-21-2009, 05:41 PM
garync1 garync1 is offline
Re: '01 PATS key in steering column
Hey.. What I did i bought a blank transponder key off ebay.. I think.. 14 bucks shipping.. Now here is the not so hard part.. Some locksmiths have the computer to activate them... I only had one key so they had to activate them. If you have 2 OEM keys you can do it yourself.. But sounds like you had the same deal I had. Only one key.. So call around to local lock smiths some may have it.. Cost me 30.00 bucks.. Dealer wanted 90.00
Just when you think you are done. Your not!! Clean the tools. Then you are done.
Nothing impresses a single mom better than a single dad who drives a minivan.Just kidding
