Closed Thread Show Printable Version Show Printable Version | Email this Page Email this Page | Subscription Subscribe to this Thread
Old 08-30-2007, 07:20 PM   #1
bojackle
96 cavalier stalled, will only kind-of start
full description:
- car ran great
- let cousin drive car home
- she got in, started it up, it idled for 10 seconds then coughed, spluttered and died
- car won't start again
it acts just like it ran out of gas, but it definitely has some. here's the weird part - every 4 or 5 times you try to start the engine, it DOES start, as in revs up and sounds like a million dollars. for 2 or 3 seconds. then it dies again. so gas is definitely getting in, and when it does start it's definitely firing properly.
so far someone has suggested the fuel filter, that some blockage is periodically getting out of the way to let it start every now and then, then immediately blocking again.
i'd appreciate any ideas or pointers that anyone has!
bojackle is offline
Old 08-30-2007, 10:51 PM   #2
doberman_52
doberman_52's Avatar
Send a message via MSN to doberman_52
Re: 96 cavalier stalled, will only kind-of start
When is the last time you changed the fuel filter? I would try that first, only about 8 to 10 bucks for one round here.
1994 Honda Civic - D15B7 W/5 spd
2000 Olds Intrigue - 3.5
Cory
doberman_52 is offline
Old 08-30-2007, 11:50 PM   #3
bojackle
about 20k miles i suppose. couldn't hurt to change, it's nice and cheap.
bojackle is offline
Old 08-31-2007, 09:15 AM   #4
taillight
First don't let your cousin drive and second get a fuel pressure guage and test the pressure.
taillight is offline
Old 09-10-2007, 09:11 PM   #5
bojackle
alright fuel filter is changed and had no effect, so next step is fuel pressure test which could mean fuel pump?
bojackle is offline
Old 09-10-2007, 11:32 PM   #6
millrtime
why not just turn on ignition and listen for the fuel pump. in my 03 u can hear the whine of the fuel pump before starting the car. that would proly give you a hint as to if the fuel pump is working or not.
millrtime is offline
Old 09-11-2007, 12:43 PM   #7
bojackle
the fuel pump is whirring as loud as it ever has, for 2-3 seconds whenever the key hits the 'on' position. however i've been told this may not mean it's working well enough to fuel the engine.
if it's not the fuel pump, what could i look to next?
bojackle is offline
Old 09-11-2007, 03:12 PM   #8
taillight
Test for pressure.
Old 09-20-2007, 04:36 PM   #9
bojackle
so the fuel pump's the problem - disconnected the filter's feed line (so it was just the pump squirting out fuel), started the car, you could hear the pump whirring and making a gargling sound, but absolutely no fuel came out whatsoever. and there's definitely fuel in the tank.
now my problem is, how the hell do i get the large black rubber filler/vapor tubes off the tank! i undid the clamps, and have been working at loosening them for a half hour, but they won't budge!
bojackle is offline
Old 09-20-2007, 06:10 PM   #10
bojackle
well i finally sprayed them up with lube and got them off, now there's only 1 line left - some fuel line from the engine that has a different quickconnect fitting to the other lines
http://i13.tinypic.com/68lzwaa.jpg
http://i10.tinypic.com/680z1br.jpg
it's in the middle, that black tab with 2 white spots. no amount of pushing pulling squeezing gets it to budge
edit: finally forced it loose with a hacked up quick-connect tool, starting new thread with the rest of the tank dropping procedure
bojackle is offline
Old 01-25-2008, 10:21 PM   #11
anomaly_va_1976
FYI People... low fuel will burn a pump up quicker than anything... it actually uses fuel in the tank to cool the pump.... it will last longer if you keep at least 1/2 tank in it...
Don't Worry What Others Think -
They Don't Do It That Often!
James Collier < [email protected] >
1992 Chevrolet Cavalier Z24 Convertible (3.1, 5-sp) *** FOR SALE -- SEE CAVALIER CLASSIFIEDS ON AUTOMOTIVE FORUMS.COM***
1993 Chevrolet Beretta (3.1, 3-sp auto)
1995 Mercury Marquis (Taxicab, i.e., breadwinner)
anomaly_va_1976 is offline
Old 01-26-2008, 12:23 AM   #12
'97ventureowner
'97ventureowner's Avatar
anomaly_va_1976 please stop bringing up old threads or risk a temporary ban on your account. Closed.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
'97ventureowner is offline
Closed Thread
