| Nissan 350Z/370Z | Infiniti G35/G37 Coupe Includes the VQ35DE, VQ37VHR - Z33 and Z34. |
350Z Engine Grounding/Earthing Kit:
Automotive electrical and computer systems are designed to tolerate up to 100% noise on its input lines. Meaning, if the ECU is expecting a 12-volt input signal, the signal may vary in the range of 0 to 12 volts. Fluctuations in signal are due to noise in the system. Noise is generated by spark plugs firing, discharges through the tires to the road, alternator turning on/off, etc. In other words, there is a lot of inherent noise an automotive electrical system. One of the best-proven ways to compensate for noise is with proper grounding. When measuring a DC (direct current) signal, almost any kind of wire will due. However, when measuring a high frequency input (i.e. the mass air flow sensor or the air/fuel mixture sensor) it is necessary to run a ground wire in parallel with your signal. The engine grounding/earthing kit provides grounding along side each signal wire. The 350Z Engine Grounding/Earthing Kit allows for cleaner data transfer to the ECU. The result is more accurate measurements by the ECU and therefore more accurate performance, smoother idle and acceleration. Each kit includes: Five grounding cables - flexible 4 gauge high temperature and chemical resistant insulated premium copper wire. Gold plated ring terminals - double crimped for strength with heavy-duty heat shrinking to protect from corrosion. All necessary bolts and washers for attachment. Complete instructions. Quality craftsmanship guaranteed! For info email: [email protected]
CS Touring, Charcoal Leather. 6MT Kick Plates, Complete Mat Set Custom Grounding/Earthing Kit |
Industrial Crimp
Crimp
Gold Terminal
Gold Terminal Connects
Heat Shrink
Heat Shrink
can you post what is involved to install it?
wtf??? i never heard that...
Application and Installation
Hello folks,
Please check out my350z.com! The Best 350Z Forum around! Do a search on "grounding kit" for all the information you would ever want to know about the grounding kit. Email me for details: [email protected]
