Go Back   Automotive Forums .com Car Chat > Jeep > Cherokee
Old 08-18-2007, 04:21 PM   #1
matholimule
Question Oil gauge jumps when decelerating(1993 Grand Cherokee)
When i come to a stop sign or sometimes when im coasting/decelerating the oil pressure gauge will jump up past 80 and bounce around between 70 and 80... when i accelerate it stays around 60... Is that bad?
matholimule is offline   Reply With Quote
Old 08-18-2007, 04:46 PM   #2
Saudade
Saudade's Avatar
Re: Oil gauge jumps when decelerating(1993 Grand Cherokee)
How about if you ask in the GRAND Cherokee forum. They are most likely better able to assist you.
Dad's taxi:
'88 XJ - 190K and going strong.
K&N, Ford Injectors, No other mods
Saudade is offline   Reply With Quote
Old 08-18-2007, 05:19 PM   #3
sector95
Okay so some of us aren't so stuck up about answering questions outside the realm of the XJ.....
It sounds like you might have a bad oil pressure sending unit....it usually lives screwed into the oil filter mounting assembly....look for a single wire leadiing down to the oil filter mount and you've probably found the sender. Make sure the wire is not shorting on anything (engine block, frame, etc) and that the connection is clean and secure. If all looks well with the wiring, I would try swapping out the sender...you'll probably have to get the sender at the "stealership" or try these guys online:
rockauto.com
napa.com
or
autozone.com
As to board etiquette...there is a Grand Cherokee specific site for you to post your questions regarding your Jeep...and you'll probably get better info there.
Good luck....
Mike
00XJ
sector95 is offline   Reply With Quote
