Emergency brake light
Have a '96 Contour, 4cyl. auto. My Emergency brake light comes on for no reason. It is very annoying at night because of the bright red light shining in my eyes. Is there a way to cut or disconnect the wire?
#2 | ||
Re: Emergency brake light
The light will come on when brake fluid is low
That if thou shalt confess with thy mouth the Lord Jesus, and shalt believe in thine heart that God hath raised him from the dead, thou shalt be saved. For with the heart man believeth unto righteousness; and with the mouth confession is made unto salvation. Romans 10:9-10 |
AF Premium User
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Dec 2004
let me ask you first have you had brakes worked on recently? if not check fluid in master cyl and if low add some see if it go's out. if it goes out i'd pull rear wheel's see if wheel cyl is leaking if you don't have rear dist on it. but if light go's out your master cyl could be leaking. so keep a eye on it for a couple 3 day's if you have to add. another thing is e-brake might be stuck on a little......good luck......
I'll vote for low fluid as well. Unless it has a pedal (i don't remember) that is a little sloppy. If it does maybe it just needs a little adjustment to tighten things back up.
having the light go on, yes it means your fluid is low...
also means to have your brakes checked to see if you have any material left on the front brake pads, for example... thinning brake pads will lower the fluid level in the master cylinder... |
