Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Register FAQ Social Groups
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 05-12-2007, 11:09 PM
notarealblonde notarealblonde is offline
Cool idles bad with a/c on
94 eclipse idles great until the a/c is turned on then it dies.
Old 05-13-2007, 01:13 AM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Re: idles bad with a/c on
Sounds like the A/C is putting too much of a drain on the system, so have the battery and alternator tested to rule those out. Autozone does it for free.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 08-04-2007, 08:00 PM
jeremytalon92's Avatar
jeremytalon92 jeremytalon92 is offline
my friend from uti said that my 92 talon turbo has a bad vacuum leak,thats why the rpms are jumping and your a/c cuts the car off when stopped i assume is also whats happening on your car,well that is what mine does.so i wounder if its a crack or hole somewhere in the intake manifold or gasket which keeps it from getting enough air.
kosei black powdercoated 16'' rims,hyoshi muffler,removed smaller honeycomb in maf,ngk wires and plugs,luk clutch and pressure plate,stock flywheel,traction t/a bfgoodrich tires,silverstar ultra headlights
