Am I Imagining Things
Am I Imagining things
I decided to fill-up my 99 3.8 Intrigue with premium fuel and the engine seems to be much stronger. I believe I can feel a real difference. What do you think am I imagining things and wasting my money on filling-up with premium fuel. |
A990 racer
![]() Join Date: Mar 2002
Re: Am I Imagining Things
Waste of money, relatively low compression engine designed for 87 0ctane, in stock form
My info says if the owner's manual says to use regular, then your wasting your money buying premium.
If your vehicle knocked or pinged using regular, switching to premium should help. If the knock sensor detected a knock, it should retard the timing a little, if it is retarded too much, you would notice a performance issue. I can't say that the difference you feel is a timing issue, I don't know. There is a higher detergent gasoline, called " top tier gasoline ", they say it will help performance, supposed to clean injector and intake valve deposits, better than the other gasolines. Gasoline is so high around here, I get the cheapest stuff I can find. |
I have also noticed that premium fuel seems to run smoother. I do not think it is our imagination. I think it is related to the flame front being more controlled and less explosive and expanding more evenly with the premium fuel.
The only way to tell for sure would be to hook it up to a scantool and test it under similar circumstances with each grade of gasoline to see what sort of timing you were getting.
I switch between 87 and 89 quite often, because several stations around here offer 89 at the same price if not cheaper than 87 because its 10% ethanol, and that little bump in octane seems to make no difference to me.
2000 Oldsmobile Intrigue 3.5 DOHC V6 Mods: Fenderwell Intake, High-Flow cat, U-bend delete, 12-inch front rotors, GMPP handling kit, 20% tint, Pioneer front and rear speakers, Eclipse HU, cleared corners 1986 Jeep Cherokee 2.8 V6 |
There was previously a thread that discussed this issue. I know that the Northstar engine senses if knocking occurs and retards the timing automatically. Different years of the Intrigue recommend either regular or mid-grade. The best reason to buy premium gas is to get extra additives that prevent carbon build-up. For tier-one gas, premium usually has 5 times the additives that regular has.
People who buy no-name gas from Mom and Pop stores to save a few pennies short-change themselves because usually the gas doesn't have very much (if any) additives in it. |
#7 | ||
![]() Join Date: Sep 2004
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people. ![]() If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno |
#8 | |
The reason i am buying premium these days is due to the fact that premium costs only 6 cents more per litre vs regular gas. Here in the Toronto area the Esso staion sells regular for $102.9, Mid-Range and Premium for the same price of $108.9, I asked the attendent why the mid range and premium are the same price he said they have an over supply of premium due to more people using regular in their cars. As long as premium is sold at that small price difference vs regular I will use premium the 3.8 is running better.
#9 | ||
A study of independent gasoline stations shows that they sometimes don't even meet the federal standards for additives to prevent clogging of fuel injectors. So, the bottom line is that it is worth spending a few pennies more for tier-one gasoline. |
#10 | ||
Probably the reason the 3.8 is running better is because the gas has plenty of additives and its burns cleaner. Hence, the engine has more pep. |
#11 | ||
#12 | |
Yours doesn't run well on sunoco regular? I seem to have good gas mileage and normal performance with that. That being said, I always use BP/Amoco, as there are many of them conveniently located on my routes. Whenever I can, I use shell. Never will I use Getgo or Kwikfill or Sheetz. Back when gas dipped down to the low 2's, I started using premium for a little while and didn't really notice a difference. Just curious, someone mentioned that some intrigues require 89 octane. I thought they all only called for regular, no matter which engine. Can someone back my thought up?
#13 | ||
#14 | |
Rolm: I have no doubts that your engine did feel stronger. This winter i had a few misfires which I attribute to the gas line antifreeze I added (HEET, I believe). I added a couple of bottles of Chevron Techron to clear up the lines (it was suggested by someone in another forum). I swear my engine felt stronger and it did help clean up the fuel. But I did not experience better gas mileage (I keep a notebook in my car to track mpg). If your Intrigue runs fine on 87 octane, then using 93 is a waste of money. If it makes you feel better, use 93 for every fifth fill up.
Now having said that, I don't buy the "top tier" vs. "cheap gas" argument. I live in southcentral PA (not to be confused with southcentral LA). This area is dominated by Sheetz, Rutter's, Turkey Hill. You would be hard pressed to find Exxon, Mobil, Sunoco, Shell, etc. (Haven't seen a Chevron station in about a decade). In our area, there is one distributor for all the gas. I need hard proof that a) the additional additives that Shell, Amoco, Chevron add to their fuel are necessary and b) this "cheap gas" is bad for fuel lines and engine. BTW, a definition of "cheap gas" would be nice. My 2000 Intrigue has 144k miles and the last 5 tanks have averaged 27.5 mpg. I have never cleaned the fuel injectors and the current fuel filter has been on for about 80k miles. I did some searching on the internet and haven't been able to find these answers. I found tons of articles on Top Tier gas but nothing that says it is necessary for the average car? If I had a BMW or Mercedes then yes I would fill up with 93 octane at Exxon all the time. Instead I have a 8 year old car with 144k miles on it. I'll fill with the cheapest gas I can find and save my money for other things. |
#15 | ||
Here are a link for you. There are others but they go to car forums which I'm not alllowed to post. http://www.aa1car.com/library/bad_gas2.htm |
