Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Register FAQ Social Groups
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 07-05-2007, 10:26 AM
sabrewlv288 sabrewlv288 is offline
Question 1995 talon tsi trouble
Alright I'm new on here so forgive me. I just got a 1995 Eagle Talon TSI AWD turbo with a 6 bolt engine swap. There is some minor problems with the car I would like answered if at all possible. First question is the lumpy idle. He said it has HKS 272 cams and i was wondering if this is why they are lumpy and occasionally feel like the car wants to stall. Other than that when I'm cruising sometimes the whole car will start to shake and my air fuel ratio guage will go wack and the problem will go away once I turn the car off then cut it back on. It happens randomly and he told me it's the wrong ecu for the car is it possible he used the 95 ecu? Which ecus work for the 6 bolt engine? The problem actually happens quite frequently and mostly in 5th gear. It's extremely annoying to turn my car on and off all the time. Another thing is when I get down on the car there is a loud sound that sounds like a loud humming I was wondering if all 6 bolt engines do that when in high rpms. Also the clutch engages almost at the floor. Do I just need to adjust it? Any help would be appreciated! And thank you for being patient I used to be a Honda guy!
Old 07-08-2007, 11:25 PM
eclipse98gst's Avatar
eclipse98gst eclipse98gst is offline
Re: 1995 talon tsi trouble
The reson the car shakes is because your getting a cylinder missfire. It commenly happens in cars with 6bolt swaps. The only way to eliminate this is to either do a resistor mod on the cam angle sensor or buy DSMLINK to solve the problem. Search for Cylider Missfire or 6bolt Swap in the forums and youll find a more detailed answer on this subject.
Speed: a scalar quantity which refers to "how fast an object is moving." A fast-moving object (my DSM) has a high speed while a slow-moving object (your Camaro) has a low speed. An object with no movement at all has a zero speed (most Mustangs).
Old 07-08-2007, 11:49 PM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
The 272's are indeed why you have a lumpy idle. That is normal. The clutch pedal can be adjusted so that it engages higher if you wish for it to... The 95 ecu is fine. Actually, only 95 ecu's are socketed and can be used with DSMlink. So I would hold onto that ECU since they are hard to come by... As far as this cylinder misfire issue, I'm not sure how to deal with it if it is indeed from the swap. My swap is almost finished and I'm hoping to not have that problem...
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06
  • 14 Silverado 1500
