Register FAQ Social Groups
Old 10-08-2007, 12:25 PM
haredog haredog is offline
98 tahoe 5.7
I have a 98 5.7 vortec, that just recently had problems starting, I hooked it up to a scanner and everything says its alright. Well not entirely, I had several misfires on a couple of cylinders. I replaced plugs and wires no change. Checked timing and I was within +/-.2DGRS OF 0, reset to exact 0. Its as if the starter is fighting the timing. And when or if I do get it started it backfires (or pops) within the exhaust system. I've heard the distributors have been problems but don't know what or even its that true. Fuel pressure is okay, no leaky intake gaskets that I can tell. Any ideas?
Old 10-08-2007, 01:43 PM
abaird abaird is offline
Re: 98 tahoe 5.7
Ignition timing on these motors is completely controlled by the computer. If you start turning the distributor you will mess up the base timing and that could definitely cause running problems and probably turn on a SES light. One thing I have noticed with my 97 k1500 that I used to have is that the dist. cap was prone to getting moisture in it and that would cause misfires.
2009 Silverado 1500
2002 Camaro Z28(rebuilder)
2005 Yamaha GP1300R
Old 10-08-2007, 05:29 PM
UncleBob UncleBob is offline
AF -Advisor
Re: 98 tahoe 5.7
as abaird said, timing is completely controlled by the computer, you can spin that distributor around 180* if you like, it won't change the timing. But if you go too far it'll throw off the cam sensor (in the distributor) and the cap posts won't be lined up with the coil fires
If you use a scanner thats capable, it'll tell you the crank to cam sensor offset, and using that you adjust the distributor to get the offsets zero'd
That may or may not be your problem, but if you've been messing with the distributor, you should definitely start there
life begins at 10psi of boost
Three turbo'd motorcycles and counting.
