Go Back   Automotive Forums .com Car Chat > Volkswagen > Jetta/Vento/Bora > '91 - '96
Old 05-21-2007, 07:02 PM   #1
grandam92
Angry 1995 jetta 2.0
ok i cant start the b****. i think a wire is loose or maybe a bad ground. when i turn the key nothing happens but then when i wiggle the wheel up and down with the tilt off it'll start?...any suggestions
grandam92 is offline   Reply With Quote
Old 05-22-2007, 09:46 PM   #2
veedubmechanic
VDUBMAN
veedubmechanic's Avatar
Re: 1995 jetta 2.0
pull the steering column cover off (its 3 screws on the bottom and 2 behind the wheel (just turn the wheel) there philips screws. Take it off and check to see if any wires are frayed or melted or blackishbrown. IF the wires are ok than you need to replace the ignition switch electrical portion.
my 95 gti's dash started on fire from the electrical harness in the steering column and fuse pannel. Then my insurance company totalled it. Good thing I bought a 01 with no wiring issues.
veedubmechanic is offline   Reply With Quote
