so yeah iam new... ok so my 92 nissan XE feels like if it was running on only 3 cylinders... but i really doubt it cause it really doesnt shake to violently when idling... so yeah.. iam here for other suggestions...what i think on my part is that my fuel injectors might be bad but iam not so sure... i did take to my autos class... unfortunatly the machine was unable to dianose my car so right now iam just stuck. When i drive it it really doesnt accelerate like its suppose to... its really slow at accelerating and stuff... especially when i have to go from a dead stop to you know go... it feels like it just gonna go off unless i give it more gas and keep the clutch in more... so yeah, any help would be greatly appreciated... thank you!
Re: Feels like iam running on 3cylinders
Make sure to check your regulars... fuel filter, plugs, wires, air filter, etc. You did that, right?
yeah pretty much checked all my regulars spark plugs look good too... fuel filter looks alright and stuff... i am just stuck!... and its funny how this just happend... i was driving then one of a sudden there was like a major slow down..now i cant even get to fifth gear cause it starts putting..like it cant even accelerate in fifth anymore one thing you hear is *PUT* PUT* PUT* *PUT* and there is no acceleration and shakes very violently... so yeah keep any other suggestions coming.. ohh and thanks ProZach626 for your help!!!!
![]() Join Date: Jan 2005
check clutch adjustment, could be your clutch is going. also do a compression and fuel pressure check. check fuel pressure at idle and under load.
reset your ecu, check voltages to maf sensor
2005 Aztec Red Spec-V Nismo header, ES MMI, AEM CAI, UR Pulley, TB Coolant bypass, TWM SS, Kumho Ecsta's, 2x JL Audio W0 subs 9.02@ 84.4mph in the 1/8th....... Driver > Car |
Any sulfer/fart smells coming from your car ever? It really sounds like there is a chance it could be the catalytic converter. Any trouble starting? When I had my old car my cat went out while I was driving. Engine revved up and car slowed down. Check that out.
#7 | |
well just checked the recent replys so.. umm the first one was about the
clutch adjustment: well that couldnt be much of a problem cause the clutch is still pretty good it was replaced like last year i think...BUT!! i will check my compression and fuel pressure thats for sure! alright the second reply about reseting my ecu and checking voltages to the mass air flow sensor. at first i always thought it could be something electrical becuase the person that had this car before me (my uncle) he likes to screw with electrical things.. sooo one of the battery cables was like chewed up but i just fixed it and it seems good one thing iam concerned about it that thing in the middle called the "ECCS" when ever you rev the ingine you can hear it clicking on the lower right side right where the throttle body is at makes like a ticking noise... what i think it might be that throttle body sensor on the side or something but still not sure. and to the third reply about the muffle and smells i really doubt it cause its a Chicago car and trust me emissions there are a bitch! and yeah i have checked for that no smells nothing just running right. so yeah thank you all for your replys and yeah i gonna go and check my compression and fuel pressure in my car when monday comes cause i dont have the right tools here at home. so yeah keep other suggestions coming!! (damm that was long lol) |
#8 | ||
#9 | |
did you reset your ecu or did you just fix the battery cable, if your ecu isnt sending proper siganls to your injectors you may see misfiring and/or lack of power, your maf sensor could not be fried but on the way out and throw your a/f ratios off just a tad, at low engine speed it could also be your O2 sensors, sounds like youre running rich but you dont smell anything funny in your exhaust? a compression and fuel pressure test should eliminate the other two things on that list and if you still cant find the problem maybe your just not used to 1.6 liter POWAH!!!!!!!!!!!
#10 | |
have your injectors cleaned, its a 92, regardless it would be good to know that your end point to your fuel system is totally clean, and as for your clutch, if it was recently replaced it could have been adjusted imporperly, if you have to hold the clutch in and give it gas more than you should then maybe its too snug, how is pedal feel? check the alignment of it and see if loosening the cable 1-2 turns helps you out any
#11 | |
check and see if your brakes are rubbing, do you hear any noises from them, hows your alignment?
#12 | |
oil fill level? too much oil can cause slugishness, if your close to an oil change do an oil analysis and see if you have any coolant or metal in it as well
#13 | ||
Another noob question coming Gotta learn some way and I want to learn as much as possible. My spec v = my project learner. Anyway... how do you clean your injectors since you aren't supposed to use injector cleaner on the spec v. Also.............................................. . where are they located?? |
#14 | |
have a shop do it, they have some kind of tool that uses sound waves to clean the plaque off the nozzles, the injectors are under the intake manifold on the firewall side of the engine, they look like your spark plugs almost
#15 | |
with wires coming out of them of course.
