Failed emissions test
I have a 95 5.7. It runs perfectly But I had the state emissons test done and it failed. CO% was fine But the HC ppm was 381 at idle (limit is 220) and 386 at 2500 rpm.
Does anyone have a idea where to start? Like I said the truck is running great. I have 30 days to get it straight, Any help would be apprecaited. Thanks |
Re: Failed emissions test
I also forgot to mention the truck has had recent plugs, cap, rotor, wires, air filter and temp sensor. Truck has always run well just regular maintanace.
EGR valve maybe? |
Did you make sure the truck was at operating temperature before the test was performed? If the cat isn't hot enough it will not perform properly.
While I haven't had this problem on my truck, I had a smiliar issue on a car I own with high HC at idle. 337 - first test Changed PCV, cap, rotor, wires, plugs, oil 328 - second test O2 sensor changed 280 - third test Changed catalytic converter 23 - fourth test |
Thanks for the responce,
It was at 210 deg for around 1/2 an hour. I am going to do some work to it and make sure I don't have any vacuum leaks or bad wires. The problem is can have it rechecked once for no extra charge. But I may have to start shelling out cash if it fails again. Any other suggestions are welcome |
My HC count was right at the limit on it's last smog test with the previous owner. I installed complete new exhaust c/with edelbrock headers and passed with flying colors. My truck doesn't have a smog pump.
One other thing I read when I was researching possible causes of high HC was that high fuel level in your tank may be a cause as too many fuel vapors are being sent to the TBI and not being burnt. I don't know how true that is though.
1949 Chevrolet 1433 (Canadian 1 ton cab and chassis single rear wheel pick-up truck) 1968 Pontiac Parisienne (rust free survivor) 1973 Buick Centurion (four door hardtop; engine will be donated to our 1949 1 ton truck) 1989 Chevrolet K3500 RC/LB (454 & single rear wheels) 1991 Chevrolet Caprice Classic (police cruiser clone) 1992 Chevrolet K2500 EC/SB (almost rust free daily driver) 1998 GMC C1500 EC/SB |
Not sure how accessible your cat is but mine had a flange on the downstream side that bolted directly to the exhaust pipe. The gasket was $2.50, when I shined a flashlight into the pipe andlooked inside virtually all the ceramic honeycomb was gone so I was pretty sure that was the problem. Somewhere I read about testing for backpressure in your exhaust system using a vacuum gauge. You could probably google that and it might help you determine if your exhaust is restricted.
The cat "filters" out the HC's, and is most likely your problem. If your truck still has the stock cat, I would replace it.
89 Chevy K1500, Extended Cab, Long Bed, 5.7L, 700r4 tranny, 10 bolt rear Things Done- Flowtech Headers, Heartthrob Deep Tone Dual Exhaust, Airaid TBI Spacer, K&N Intake, 3" Performance Accessories Body Lift, 285 75 R16 Pro Comp A/T Tires, 16" Americain Racing Outlaw 2 Rims, Fabricated Bumper Replacement. |
I guess I'll have to look into getting a cat. It is the stock converter. Thanks for all the info.
Yes, I would check the cat and also the oxygen sensor.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1! 2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness! 1967 El Camino L79/M20 old school asphalt raper Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have. |
UPDATE:
The truck finaly passed. I decided to check the distributor again and when I removed the cap it was all green . I replaced the cap rotor and coil. Then ran it to the emmissions station = pass . I don't have the numbers in front of me but they were low. I didn't check the cap at first because it only had about 8000 miles on it and I assumed it was OK. I hope this may help if anybody runs into the same problem.
