Go Back   Automotive Forums Car Chat > Pontiac > Grand AM > Tips and Maintenance
Register FAQ Social Groups
Tips and Maintenance Post helpful tips, maintenance guides and R&R procedures here
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 01-15-2007, 06:21 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Thumbs up Camshaft Position Sensor- Testing and Replacing on 99-00 Grand Am's
Testing and Replacing the Camshaft Position Sensor
The Camshaft position sensor works along with the Crankshaft position sensor.
Determining the timing and injectors’ pulse, to deliver fuel to the cylinders.
The Camshaft position sensor is a hall sensor, which it triggered by a magnet in the Camshaft.
On 4 cyl(2.4) models the Camshaft position sensor is located to the left side of the timing cover.
On the V6(3.1 & 3.4) it’s located at the front of the engine block (passenger side), below the power steering pump.
Check the terminals for breaks and looseness, repair if needed.
Here is the plug indentification picture.
The wires are different for the 4cyl and V6, Please note below.
Though the plugs are the same three wire connectors.
Plug is as listed :
1 - Camshaft position sensor signal on 4 cyl,
12 volt supply on the V6
2 – Sensor ground 4 cylinder,
Camshaft position sensor signal on the V6
3 – 12 volt supply on the 4 cylinder,
sensor ground on the V6
First check for voltage and ground circuits from the PCM.
Disconnect the electrical connector from the Camshaft sensor and connect the positive lead (on the wiring harness) of the voltmeter to the red wire(#3) on the 4 cyl and the red/white wire on the V6(#1).
Connect the negative to the pink/black wire on the 4 cyl(#2), or black on the V6(#3).
Turn the key on, the voltmeter should read 12 volts, if not check the wiring to the PCM.
If the circuits are good, have the PCM checked out by a Dealer or other properly trained shop.
To check the operations;
Reconnect the Camshaft position sensor, using a probe to back probe the brown/white wire terminal of the camshaft PS. Plug locations on4 cyl (#1) and theV6(#2)
Connect the positive lead of the voltmeter to the probe and the negative to a good engine ground.
Turn the key on, the voltmeter should read approx 10 volts.
*Rotating the engine by hand with a breaker bar attached to the crank pulley. Watching the voltmeter, the voltage should remain a steady 10volts then quickly drop to zero and back to 10vlts as the magnet passes the sensor.
If the tests results are incorrect then replace the camshaft position sensor.
* Rotating the engine slowly, and at least two full revolutions of the engine for accurate results.
Camshaft sensor Replacement
On the 4 cylinder
- Disconnect the electrical connector
- Remove the camshaft position sensor-mounting bolt and pull the sensor out of the camshaft cover.
- Replace the “O” ring and lightly lubricate it with clean engine oil.
- Install in the reverse of those procedures.
On V6
- Remover the drive belt.
- Remove the power steering unit but don’t disconnect the hoses, just lay it aside.
- Disconnect the electrical connector from the harness; paying attention to the route the wires are in.
- Remove the camshaft ps mounting bolt and pull the sensor out of the block.
- Install in reverse procedure.
-- If the sensor flange breaks off and you cant remove the CPS, try screwing a heavy screw into the top of the sensor and pulling it out with plyers/visegrips.
1999 Grand Am SS 3.4 OHV
Closed Thread
