Go Back   Automotive Forums .com Car Chat > Cadillac > Eldorado
Old 12-05-2006, 02:17 PM   #1
borninabarn
Starter Replacement 94 4.6 Northstar
I need to install a starter motor in my mothers 1994 eldorado with the northstar.I looked up michell time and shows around 4 hours.Are there any big problems doing this job before i start tearing it apart.I have done alot of repair work but just havent torn into one of these before.Thanks Born
borninabarn is offline   Reply With Quote
Old 12-06-2006, 01:47 PM   #2
borninabarn
Re: Starter Replacement 94 4.6 Northstar
Is there a way to test this starter in this 4.6 to absolutly confirm this is the problem?
Old 12-06-2006, 03:10 PM   #3
DFBonnett
You can do a starter draw test with the starter in place which will tell you how many amps it is drawing under load. You need a special meter for this.
What symptoms are being exhibited?
DFBonnett is offline   Reply With Quote
Old 12-23-2006, 01:28 PM   #4
e.sedgwick
I have a 1994 Touring Coupe and a factory service manual. After looking at the procedure to replace this starter, I had the dealer do It. ($500.00) You might be able to do it but it sure isn't going to be easy. You might shop this job and get abetter price
e.sedgwick is offline   Reply With Quote
