Register FAQ Social Groups
Old 12-11-2006, 10:46 AM
pepis2 pepis2 is offline
1995 s10 4 wheel only front brakes work
When In 2 Wheel Only Have Front Brakes Working In 4 Wheel All 4 Brakes Work , WHY?
Old 12-16-2006, 09:49 PM
bm2boats's Avatar
bm2boats bm2boats is offline
Re: 1995 s10 4 wheel only front brakes work
This is normal. 2 wheels driving 2 brakes working unless you are stepping heavy on the brakes then all wheels locks up. 4 wheels driving then 4 brakes are needed to stop.
EMS Motto: Your Misery is OUR Pleasure
Old 12-16-2006, 10:51 PM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
WTF?
I suggest you stop taking what ever drugs your trying.
pepis2, some more details would be helpful.
How do you know only the fronts work in 2WD?
How do you know all 4 work in 4WD?
The two systems are quite separate from each other, and there will be a lot more front bias, then rear bias, so the front wheels are more likely to lock under hard braking.
But, if in you have locked centre diff when in 4WD, locking both front wheels with the brakes, will also lock the back wheels.
This is quite normal.
