Go Back   Automotive Forums .com Car Chat > Chevrolet > Blazer > Performance
Performance Discuss Engine, Suspension, Drivetrain, and all other performance modifications here.
Old 12-08-2006, 06:25 PM   #1
mike_flemming
need quick answers about TP mod!!
I have read he post about it and i just need a couple things cleared up! i have a 2000 s-10 2wd with a 4.3l vortec vin code "w" i belive. I assume the tp mod can be done on this motor i just want to double check! also, can this be done by just taking out the plate or is it better to remove the whole throttle body? last question, descreening the MAF? some say good others say bad? any final verdict? thanks in advance, hoping to get at this tomorrow
mike_flemming is offline   Reply With Quote
Old 12-08-2006, 07:38 PM   #2
ZL1power69
GM S-Series Mod
ZL1power69's Avatar
Re: need quick answers about TP mod!!
yes the mod is for the 96+ 4.3 v6 "VIN W". it is not required that the throttle body be removed but its highly recommended because its easier to work on and there is less risk of you dropping something down the intake. after removing the two torx screws, open the TB to WOT then slide the plate out the top side of the TB. The deflector is made of thin alluminum so you can cut it off with a hack saw or cut it off with a dremel. just make sure u don't mess with the rivits or the hole in the plates. o and descreening the MAF is not a good idea as it helps straighten out airflow and protects the elements in the sensor. there is really not a gain in performance with it off so its not worth risking damage to the sensor.
2000 Chevy Blazer ZR2
Performance Mods: Numerous
Suspension Mods: Some, but not enough
Exterior Mods: Just Right
1987 Buick Turbo T Dark Red
Low 11 sec sleeper
.030 4.1 block, PT6262E, & other odds and ends....
My Cardomain
ZL1power69 is offline   Reply With Quote
