Old 11-21-2006, 08:04 PM   #1
FabricGATOR
Send a message via AIM to FabricGATOR
Beware the Serpent!
Hello,
I have a 2001 Rodeo that I just bought with an apparent good motor.
The A/c clutch was seized, belt shredded. I replaced the compressor, and belt. The new belt moved to the front of the crankshaft pulley, the rear of the waterpump pulley and began to wear as it rode out of position.
I checked the tensioner and found that while it had its center bolt, that someone had not realized that there was a bolt that was supposed to go through the tang (ear) of the tensioner.
I repaired it, put new belt and again, same disaster.....
I replaced the tensioner, thinking that somehow it may have worn from being improperly installed. No change....
I replaced the grooved idler pulley as it had some play in the bearing. No change...
I disconnected the ignition so it would not start and observed the belt as it cranked slowly. As soon as the belt comes off the tensioner pulley to the crankshaft, it jumps ahead one groove. It wants to ride to the back of the waterpump pulley and that is where the belt gets worn out..
It appears that the alternator was recently changed and that is when I assume that the (mechanic) missed the bolt on the tensioner.
I hope that someone could share that they also were frustrated with this similar circumstance and they found.......
Thank you for looking and even more thanks if you can help me find the cure!!!!
Hey! I'm not considered an enthusiast anymore........
2010 Toyota FJ Cruiser Trail Team Edition
2000 Mitsu Montero Sport (Trade In)
1987 944 N/A
1976 Buick Century (SCRAPED)
1979 Yamaha XS1100
I have a parking problem everywhere I go...
2004 Pontiac Gran Prix . . I don't care.
1993 Mustang LX . . . . . I don't care..
1996 Honda Civic CX. . . . . I don't care, well, maybe a just little...
I can't afford to love her anymore!
FabricGATOR is offline   Reply With Quote
Old 11-21-2006, 08:14 PM   #2
rodeo02
Re: Beware the Serpent!
Cool! Glad you got it. Keep in mind- that pulley that looks like the waterpump, is not. It's just the fan drive pulley. Some books call it a dummy waterpump as the actual WP is run off the timing belt, burried under the T-belt covers. That dummy waterpump triangular shaped bracket is another common failure item that cracks and sends the serp belt flying.
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
rodeo02 is offline   Reply With Quote
Old 11-21-2006, 10:41 PM   #3
Gizmo42
Gizmo42's Avatar
If its getting out of alignment around the crank pully it could be a bad harmonic balancer, or the pully wasnt put on correctly. I dont think the '01 models suffer from a crank walk problem but could be wrong.
--Dave
1999 Rodeo LS 3.2 4x4 5 Speed
32x11.50-15 BFG T/A KO
3" Lift - Rancho 9000x
Rear No-Slip Locker
Flowmaster 2.25" 50 Series
There is a very fine line between "hobby" and "mental illness." - Dave Barry
Gizmo42 is offline   Reply With Quote
