Go Back   Automotive Forums .com Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 10-24-2006, 04:55 AM   #1
Locc
Distributor Noise
My 85 Cutlass has a knock coming off of the distributor, I have no idea what causes it, it comes and goes although lately it seems to come more than go.
I changed the cap, rotor, ignition coil, plugs and wires not long after I bought it and not long after is when I noticed the knock, all the parts are the correct ones and were installed correctly. Outside off it being some other problem, could it just be a defective piece that I installed?
Locc is offline   Reply With Quote
Old 10-24-2006, 10:25 AM   #2
xeroinfinity
out saving the world
xeroinfinity's Avatar
Re: Distributor Noise
if the caps not centered or the caps loose(not on straight) ,
the rotor could be hitting the cap.
Is distributor lockdown tight, and not letting the Dist. move?
Could also be the distributor gear or shaft ...
1999 Grand Am SS 3.4 OHV
xeroinfinity is offline   Reply With Quote
Old 10-24-2006, 11:09 AM   #3
Locc
The cap is on tight and straight, I had thought that might have been the problem too at first. The distributor bolt is tight and is no play in the distributor.
Old 10-24-2006, 02:42 PM   #4
xeroinfinity
what engine ?
Make sure the rotor is all the way down.
If its to high it will screw up the cap, sometimes they are tight and dont go on all the way.
Other than that , maybe the shaft isnt geting lubrication causing the noise.
may be its not even the distributor making the noise...
Old 10-24-2006, 03:16 PM   #5
Locc
Originally Posted by xeroinfinity
what engine ?
It's a 231 V6.
Rotor is tight down only 2 screws it sits real tight and flush.
It is definately coming from the dist. though, you can put your hand on the cap and feel the tap as well as hear it.
I heard/read somewhere about bearinggs in the dist. shaft possibly going bad?
Old 10-24-2006, 06:05 PM   #6
xeroinfinity
if everything went back the same when you did the tune up then it has to be the bearings.
I was thinking that earlier but wanted to be certain.
Probly pick up a used one cheap, I hav no idea right off what one would cost new.
