Old 08-11-2003, 05:27 PM   #1
retrev
looking for help with electrical problem
Recently, I've been having some problems with my 2000 SE's lights. When the headlights are on, my left turn signal (lights and dash arrow) turns on (solid, not blinking) and engaging the left signal does nothing...right one works fine. If the headlights are off, the left turn signal works fine but the dash lights (and headlights I believe) flash sporadically.
Seems to me that there is a short somewhere but I havn't a clue where best to start tracking this down. Anyone had a similar problem? How 'bout a little advice? I'd like to not take this to a mechanic as electrical problems like this seem to be very expensive and time consuming to track down so I'd like to waste my own time, not a $35 an hour mechanic.
Thanks in advance.
retrev is offline   Reply With Quote
Old 08-12-2003, 12:43 AM   #2
rrdstarr
rrdstarr's Avatar
Re: looking for help with electrical problem
Thanks in advance.
Try $65 an hour!
We don't give a damn how loud your stereo is!
Did you read your owners manual yet?
V.P. of PNWX
rrdstarr is offline   Reply With Quote
Old 08-12-2003, 01:15 AM   #3
krazibimmer
Send a message via AIM to krazibimmer
try checking all the bulbs on the left side of the car. i think one of the bulb could be shorted out. most likely one of the bulb with double filament.
krazibimmer is offline   Reply With Quote
Old 02-10-2004, 01:37 AM   #4
normance
I have almost identical problem with same model year but it's the left turn signal and stop light combination aggravated when the headlights are on (even park). I have measured voltages and seems to be a poor ground but due to a broken ankle have not gotten much further than that at this this time. Please keep me informed if you get it fixed.
Good luck, Norman
normance is offline   Reply With Quote
Old 10-13-2006, 06:52 PM   #5
jerry b
I just bought a 2000 SE a couple days ago and one of the things that I found when Iwas researching exterras was that they have poor grounds that often fail and cause a multitude of problems. After checking the bulbs, that's where I would start. However, I did have a similar problem with my camaro and it ended up being a short behind the instrument cluster. Good luck, you are gonna need it.
jerry b is offline   Reply With Quote
Old 10-13-2006, 08:00 PM   #6
normance
Problem Solved
I forgot to reply when the problem was fixed. I was 100% correct in my diagnoses of the problem. It was a ground problem. However since at the time my ankle was broken and my leg was in a cast I let the dealer fix the problem. They presented two options, one was a new wiring harness (about 800 dollars and 400 in labor) or to try to fix just the grounds with supplemental wiring. Since that was only going to cost $110 and and my daughter was driving the car I went that route. The dealer stated there was no guarantee for their lesser cost repair, but it work fine until the other week when the car was stolen (this was the second time). and wrecked. Anyway, Good luk with any one else who had this problem.
Looking for help, guessing electrical or sensor problems Paradisd S60 2 07-19-2010 01:36 PM
Still looking for suggestions with tranny problem for 2001 Grand Prix Ventura77 Grand Prix 4 05-01-2005 03:26 AM
I need help with Electrical problem BATMANGT Corolla/Matrix/Voltz 0 01-21-2005 07:02 PM
Need Help With Electrical Problem Frezz Suburban 4 10-06-2004 11:13 AM
Help with Electrical Problem Nerveous Integra 0 06-17-2004 02:25 PM
