Go Back   Automotive Forums .com Car Chat > Chevrolet > Cavalier > Non-Performance
Non-Performance This is the place to discuss interior, exterior, and other non-performance related modifications.
Old 09-10-2006, 11:32 PM   #1
302Z28
Coolant drain
Looking to drain coolant on a '97 Cavalier. I cannot seem to locate any drain plug on the radiator. I could pull off the lower hose, but I'd probably lose most of the coolant. Any ideas?
Thanks
302Z28 is offline   Reply With Quote
Old 09-11-2006, 01:08 AM   #2
Cold_Silence
Cold_Silence's Avatar
Send a message via AIM to Cold_Silence Send a message via MSN to Cold_Silence
Re: Coolant drain
Do u wanna drain all ur coolant? If so removing the lower hose wud do the trick, thats what i did anyways. U also have to take off the upper hose by the thermy to remove any excess.
The New Ride!! 2002 Cavalier Coupe..
Originally Posted by noshun
It's a lovely 2200, but got about as much poke as my grandma with no fingers.
www.cleanstartsolutions.com
Cold_Silence is offline   Reply With Quote
Old 09-11-2006, 12:11 PM   #3
my99cavy
my99cavy's Avatar
Send a message via AIM to my99cavy Send a message via MSN to my99cavy
Re: Coolant drain
Thanks
So your saying you dont want to drain all the coolant out???
*EDIT* But there is a drain plug located on the radiator....
The radiator drain is located on the radiator and faces the front of the vehicle (adjacent to the condenser-to-radiator bolt), it can be accessed after the lower splash shield is removed
my99cavy is offline   Reply With Quote
Old 09-11-2006, 01:18 PM   #4
Cavalier2000
Banned
Cavalier2000's Avatar
Re: Coolant drain
i am so lost, you want to drain the collant w/o loosing it
Cavalier2000 is offline   Reply With Quote
Old 09-11-2006, 02:29 PM   #5
cLaWz
Re: Coolant drain
Maybe he wants to remove it to do some kind of work but not "lose" it as in needing to replace it?
If thats the case, drain plug should work I would think. Just use a pan to recover any draining coolant.
cLaWz is offline   Reply With Quote
Old 09-11-2006, 02:31 PM   #6
302Z28
Re: Coolant drain
I need to drain enough coolant to accomodate changing of the water pump. I would like to re-use the coolant afterwards, as the system was flushed and new coolant installed about 6 months ago.
Thanks,
Old 09-11-2006, 02:32 PM   #7
my99cavy
my99cavy's Avatar
Re: Coolant drain
Thanks,
Ohhh ok that makes sense now. So did you take a look at the picture I posted of where the drain plug is??
.........ummmm duh lol jk
Old 09-11-2006, 03:23 PM   #8
Cavalier2000
Banned
Re: Coolant drain
no no no no no my friend best idea is if you need a new waterpump change that collant with it, unless it is brand new
Old 09-11-2006, 09:24 PM   #9
millrtime
Re: Coolant drain
i agree. dont change anything coolant runs through, without changing the coolant itself. it will save you a lot of headaches later. cuz if the new part has bits of metal or something in it....u dont want that getting into ur engine or anything like that. plus its not that expensive so i would just do it anyways.... thats just what i heard though
millrtime is offline   Reply With Quote
