Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Register FAQ Social Groups
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 08-10-2006, 04:07 PM
talon-95's Avatar
talon-95 talon-95 is offline
Question LOW RPM AT IDLE After Timing Belt Change
I have a question.
I just change my timing belt on my 95 Talon FWD Turbo.
Car started fine. After it warmed up, I reved it up to 4K rpm and all fine so far except for now at idle, my rpm's are at around 500 to 600 rpm.
Any idea's on adjustment?
Thanks.
Old 08-21-2006, 07:12 PM
Bodack Bodack is offline
Send a message via AIM to Bodack
Re: LOW RPM AT IDLE After Timing Belt Change
Bump.
I have the same problem and have had it for a while. Sometimes it'll kinda die out too, but it's not the IAC.
1993 Honda CBR900RR
1990 Talon TSi AWD - Sold
1990 Laser RS turbo - Sold
1993 Eclipse GS - Sold
Old 08-21-2006, 11:44 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Mine did that too. It kinda worked itself out in my case. I bounced around (unplugged IAC ) but it still was low. Eventually it went to rock solid at 700-800.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 08-22-2006, 01:48 AM
NOFX0617's Avatar
NOFX0617 NOFX0617 is offline
Send a message via AIM to NOFX0617
Yeah you are not that far off....mine idles at around 600-700
1998 Eclipse GSX
6 Bolt swap
MHI Big 16g
FP Race Manifold
Apex'i N1 Cat-back
Apex'i N1 Downpipe
Walbro 255 fuel pump
GReddy Type S BOV
Turbo XS Boost Controller
Balance Shaft Elimininator
ACT 2600
RRE 11lb No Name Flywheel
Prothane Motor Mounts
Tokico Illuminas Advanced Handling Kit
RRE Front and Rear strut tower bars
RMDSM Front and Rear Sway Bars
TRE Stage 2 Tranny
ARP Head Studs, Main Studs, Rod bolts
Old 08-24-2006, 02:18 AM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Does it run rough?
95 Talon TSI AWD
97 Eclipse GST
Old 08-24-2006, 04:12 PM
Mine runs all right, but the idle is rough. It used to idle right at 1,000RPMs, which I was ok with because it was a solid idle. Now after the timing belt, it kinda bounces around and shuts down even sometimes when it's cold. When I drove my NT Eclipse, the IAC went out, and it behaved a little differently than what mine is doing now, but I could still check it out since I have a new one lying around. Seems to be a common problem after timing belt change, so that's why I don't think it's the IAC.
1993 Honda CBR900RR
