Go Back   Automotive Forums .com Car Chat > Chevrolet > S-10
Old 08-14-2006, 09:35 PM   #1
82Stang
Question Oil cooler lines 93 S10 Blazer...
Hello,
93 S10 Blazer 4.3L 4x4 Auto
Anyone ever replace the oil cooler lines going from the remote oil filter to the radiator? I got a new set(Dorman) from the local auto parts store and it was said to fit my year. They were slightly different shaped, but they said that's what it called for. However, the air cleaner won't go down in because the lines are in the way. Every store I checked said these lines are the right lines for a 93 Vin W except one. That one said they didn't know anyone that makes lines for the vin W, except dealer and that some used the lines I got(they said for a vin C or something like that) and made the air filter fit, but I don't see how I can do that. So, I wondered if anyone has run into this problem before?
Thanks
82Stang is offline   Reply With Quote
Old 08-15-2006, 08:28 AM   #2
rlith
rlith's Avatar
Send a message via AIM to rlith Send a message via MSN to rlith
Re: Oil cooler lines 93 S10 Blazer...
No such thing as a vin C, only VIN W and X for the 6 cylinders... That said... Any chance of flexing the hose back a littl bit to get the box to slide in?
95 s10 Blazer, EGR Mod, ZQ8 Steering box mod, 99 Center console shifter mod and more... See everything at www.pghconsulting.net/teal
rlith is offline   Reply With Quote
Old 08-15-2006, 09:28 AM   #3
82Stang
Vin ?, wasn't sure. As for flexing....I might try to flex it a little, but boy it's tight!
Old 08-15-2006, 09:32 AM   #4
rlith
rlith's Avatar
Another option may be that your rad isn't seated properly. See if you can shift it towards the passenger side (do this with the top fan shroud off). You may be able to make enough room in there by doing this...
