Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 08-15-2006, 10:01 PM
Cooweesta_Vela Cooweesta_Vela is offline
Unhappy Clicking and grinding on the front end
Please help. I have a 95 neon and it makes a clicking noise all the time and grinding sometimes. It only makes this noise while going under 40-45 miles an hour and only when I'm going forward. It does this while I'm excellerating and coasting. There is also a clicking when i brake. I took it in and they said that the cv joints were fine but they did replace the tirods because they were worn, but after this the noise only got worse .
Old 08-16-2006, 01:32 AM
Wollf's Avatar
Wollf Wollf is offline
Re: Clicking and grinding on the front end
When your driving at a slow speed turn the wheel all the way one way and move forward , then all the way the other and move forward , if the noise goes away in one of those situations it very likely you have a CV joint going. Unless there is visable damage some shops have a very hard time diagnosing CV troubles but this is a decent way to do a self diagnosis that * usually * will help you know what is going on. If this doesnt show anything we can try something different after you have tried this.
I work as a partsman in the BC Area if you need help finding something you cant find pm me here and i will see what i can do. www.lordco.com
Better to sit in silence and be thought stupid , then to open your mouth and remove all doubt.
