Lumina full throttle problem
1992 lumina Euro 3.1
My car runs decent at up to 3/4 throttle, if you smash the gas pedal down, it loses power and slows down, let it back to 3/4 throttle and it picks up speed again. if I keep it at 3/4 throttle in second gear it will continue to pull up to high rpms, so I am kinda ruling out the fuel pump, or filter. I have 38 PSI fuel pressure. I cleaned the IAC valve which cured my idle issue, and did the re-learn procedure, it will idle fine, no probs when stopping. ANYONE have a guess or similar experience? I know these cars have injector probs, but it wouldnt make sense that only at full throttle it dies out. I am going to do the ohms test on the injectors later on to rule those out, but just looking for some advice in advance! thanks |
#2 | ||
Re: Lumina full throttle problem
Lactose the Intolerant
![]() Join Date: Aug 2004
Leave the fuel pressure gauge on it and tape it to the windshield if you have enough length, watch it when you go WOT.
Might wanna do a vacuum test to rule out a cat restriction, etc.
#5 | ||
Re: Re: Lumina full throttle problem
I just remembered something else, I had a 1998 chevy pick up that died on me, replaced fuel pump, filter relay, and it happened again! I ended up running a higher guage wire to the pump and it never had another problem, I might try that too, I will update this post if that cures it! GM likes to run tiny wires to the fuel pumps. I actually did that on my 97 grand prix as preventative maintenance, and that car has almost 220k miles on it! That or the fuel injectors is my guess, but keep the posts coming! thanks! |
A990 racer
![]() Join Date: Mar 2002
Your cat test won't work, the element in the cat can move with exhaust pressure, partially blocking the outlet. A pressure test on the o2 port at 1500 rpms should not be over 1.5 psi.
#7 | |
Or a vacuum gauge connected to manifold vacuum should hold steady when running at high RPM, slow drop indicates restriction.
#8 | ||
I ran a new wire to the fuel pump, it didn't seem to change the effect. now if I shift into 1st gear from a stop, slowly take off and at about 10 mph nail it, it falls on its face like you lost all power, bring it back to 3/4 and it keeps going, this is getting annoying! I bought the car from an auction, and it looks like someone else has already tried numerous things to try and fix it. It has a new EGR also. I guess I will just check the injector values so I can rule those out. |
#9 | |
Get an ohm meter reading on the throttle position sensor , then sweep the throttle open and closed slowly and look for a dropout in reading.
#10 | ||
The trans will downshift at full throttle, so I cant see it being the TPS either, but its worth a check! |
#11 | ||
Re: Re: Re: Lumina full throttle problem
#12 | ||
1963 Triumph TR3 12K 1995 Buick Century Special 178K 1999 Chevy Lumina LTZ 160K 2001 Suburu Forester 53K 2002 Oldsmobile Aurora 3.5 45K 2004 BMW Z8 3K 2005 Dodge Charger .5K 2006 Jaguar XJ12 1K
#13 | ||
and not fuel related either |
#14 | |
I got nuthin.....
#15 | |
is it possible the transmission is acting up, you say its fine in second gear... but in third it loses power. and since you have the Euro im sure you have the 3 speed no overdrive TH125c like i do.
