Old 10-22-2003, 03:30 AM   #1
redvoler
Handbrake adjustment???
Sorry for a simple question. Hope the answer is simple.
My handbrake needs to be pulled all the way up to its last ratchet before it stops the car rolling away. How do I adjust this please?
Many thanks.
redvoler is offline   Reply With Quote
Old 07-29-2004, 12:56 PM   #2
Apexi_N1
Re: Handbrake adjustment???
temporary solution. put it in gear when parked.
(that's what I do).
Apexi_N1 is offline   Reply With Quote
Old 09-15-2004, 12:22 PM   #3
tenggis
my car has the same problem and i was wandering the same thing but too busy/lazy to look into it. i had a 96 240sx before and it had a nut right under the e-brake when u pull it all the way up. i just tightened this nut. i'm not sure if it's the same on the x-trail. i'll look if it has or not tomorrow and post something.
tenggis is offline   Reply With Quote
Old 01-27-2006, 08:17 AM   #4
Sean King
Your vehicle's handbrake can be adjusted by a mechanic in the vicinity of the rear brakes at the back of the brake drum.Your mechanic is supposed to know where to make the adjustment.
For my own use I bought a CD manual for my X-trail on ebay at a small cost and all of this info and more is answered on it.
Keeping the vehicle in gear or in park can damage your gear box or transmission so this is not something that you should practice.
Hope I helped you.
Sean King is offline   Reply With Quote
Old 02-13-2006, 11:26 PM   #5
newcastlenissan
take it in to a shop, it isnt the proper way to adjust your ebrake by tightening the screw under the actual lever, it needs to be done at the caliper, or drum itself
newcastlenissan is offline   Reply With Quote
Old 04-03-2006, 07:49 AM   #6
suftuffer
Many thanks.
I had the exact same problem with my 2004 X-Trail 2.5 Sport Outdoor. Went back to the dealer and they have adjusted it under warranty
suftuffer is offline   Reply With Quote
Old 04-05-2006, 05:25 PM   #7
nissantech
remove the rear wheels and adjust through the brake disc. UK xtrails have rear brake pads but handbrake shoes. not to hard to do.
I live with fear all week, and at weekends SHE lets me go racing.
nissantech is offline   Reply With Quote
Old 04-16-2006, 04:07 PM   #8
bergkamp
I have had the same problem. Main dealer will adjust in seconds by adjusting nut under handbrake lever. Needs caution however I'm told because of anti lock brake system.
bergkamp is offline   Reply With Quote
Old 06-11-2006, 07:35 PM   #9
nissantech
No need to worry about the ABS will not effect it in any way.
