Go Back   Automotive Forums .com Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 05-21-2006, 12:49 AM   #1
ss5wil
Head Gasket Help!!!!!
I have a 97 neon with a DOHC since i'm changing the head gasket myself
i would like to know if i have to remove the camshafts from the head in order to remove the head or is it a matter of just removing the bolts and the head and camshafts coming out as a unit?
ss5wil is offline   Reply With Quote
Old 05-21-2006, 03:07 AM   #2
corning_d3
Send a message via Yahoo to corning_d3
Re: Head Gasket Help!!!!!
I'm pretty sure the cams can stay in the head, unless you have to remove them to get to the head bolts.. If this is the case, you may want to invest in a good service manual..
2007 Certified DaimlerChrysler Service Technician...
True blue GM at heart.
corning_d3 is offline   Reply With Quote
Old 05-21-2006, 03:44 PM   #3
wafrederick
Banned
You have to pull both camshafts to get the headbolts out.Make sure to break the bolts loose that hold the caps holding the cams on with a good six point socket by hand first to prevent rounding them off.I have done 2 or 3 of these and the cams had to off.Make sure to put the cams and the caps in the right spot when putting back together.There is one special tool you need,a special puller to get the crank pulley off.It is a 3 jaw puller and a harmonic balancer will not pull the crank pulley off since there are no threads for bolts
wafrederick is offline   Reply With Quote
Old 05-21-2006, 04:46 PM   #4
corning_d3
Best bet is to rent the puller at autozone. I just bought one for $90!
Old 05-22-2006, 12:06 AM   #5
das2123
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
das2123 is offline   Reply With Quote
