Go Back   Automotive Forums .com Car Chat > Chevrolet > Cavalier > Non-Performance
Non-Performance This is the place to discuss interior, exterior, and other non-performance related modifications.
Old 04-27-2006, 08:39 PM   #1
heavyredchevy
heavyredchevy's Avatar
window crank
How do I remove the window crank on a 97 pontiac sunfire to get at the door speakers?
Thanks
heavyredchevy is offline   Reply With Quote
Old 04-27-2006, 09:39 PM   #2
94VL
Re: window crank
Get the tool from KD or Motormite....its a thin,flat metal tool that will slide behind and slide the clip back to release the handle.You can also take a rag,and slide it behind the handle,and wiggle it around while pulling it back....it will usually slide the snap ring back too.
94VL is offline   Reply With Quote
Old 04-27-2006, 10:36 PM   #3
boarder_punk
boarder_punk's Avatar
Send a message via MSN to boarder_punk
Re: window crank
The tool is the best choice, you can get them from summit too. The rag trick never worked for me, but before I bought the tool I would just use 2 well-positioned small, flathead screwdrivers (can be a huge pain without the tool though as the c-clip is very small and the space is tight).
boarder_punk is offline   Reply With Quote
Old 04-28-2006, 03:20 AM   #4
CavLCD128
Send a message via AIM to CavLCD128
Re: window crank
no for the thousandth time...or however u spell that word..lol
all you need is a flat head screwdriver...it is so easy to do with a flathead that you dont need the stupid waste of money tool!
pull the window crank out so you can see the clip....and pop it out...i did it and it took me 5 minutes each...5 minutes per door vs 15.00....il spend a little extra time vs money anyday
ThE neW wHiP:
CavLCD128 is offline   Reply With Quote
Old 04-28-2006, 01:31 PM   #5
heavyredchevy
Re: window crank
Thanks, I was able to get it out with the flat screwdriver. It took a little while but it worked.
Old 04-29-2006, 08:47 PM   #6
Boomsly
Re: window crank
The rag trick and screwdriver both worked for me, the rag trick was a bit of a pain in the ass and took abit of time. Screwdriver was easy and quick.
'97 cav WIP
Boomsly is offline   Reply With Quote
Old 05-06-2006, 05:05 PM   #7
Tonto Kowalski
Re: window crank
The rag never worked for me. I also tried using a string instead of a rag and it didn't work either.
Tonto Kowalski is offline   Reply With Quote
Old 05-08-2006, 12:30 AM   #8
CavLCD128
Re: window crank
yea alot of ppl say the tool is worth it...y waste 10 bucks?
i can see it being useful if u take ur door off once a day....every day
ThE neW wHiP:
Old 05-08-2006, 12:48 AM   #9
KustmAce
Grande Boleros de Fuego
KustmAce's Avatar
Re: window crank
The tool is the best way to go.
The reasons being:
A: It will work like a charm each time, every time, with no risk of effing up your door panel.
B: GM has used the same clip system on vehicles since the 40s. That tool works on all of them.
C: $10 is pocket change. Well worth the peace of mind.
But the flathead does work.
MAKE ART, NOT WAR
KustmAce is offline   Reply With Quote
Old 05-08-2006, 01:18 PM   #10
Cavalier2000
Banned
Cavalier2000's Avatar
Re: window crank
shit never know when you'll need that tool. used that thing about a thousands times, speakers a time or two then mirrors, then friends use it it's good stuff
Cavalier2000 is offline   Reply With Quote
