| Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums. |
![]() Join Date: May 2006
88 Cutlass Ciera...3rd brake light won't work?
My car failed inspection, one of the reasons being the 3rd brake light (one on the rear seat) would not work. So I replaced the bulbs, using a 1156 (the old one had blown out). Now here's the problem:
IT WON'T WORK! I've tried 3 different 1156s, 1157s, and it still won't light up! My cousin who's a mechanic did a circuit test and it lit his tester up without any problems. Does anyone know what might be wrong here? Yes the rear tailights/signals work, it's just the 3rd brake light doesn't want to |
Banned
Re: 88 Cutlass Ciera...3rd brake light won't work?
It's probably the connector where the bulb sits and not making contact properly. The tester works because he is poking at the connector with a pointed tester. Try cleaning the connectors and use a di-electric grease on the connection. If it is barely making a connection and power is applied then it cause a spark on that connection and you got a no power problem where the connection between the bulb and connector is corroded by then.
Had fun with a multimeter...it's showing there is a complete circuit through the light. Perhaps it's a grounding issue, which is what it seems highly likely of being, and if so, how do I resolve this (without having to pay anyone to do it >_>)?
I don't get this.
I verified with a multimeter I got from radioshack that I have 12 volts going through the bulb, and I have at least 20 milliamps going through it as well. I probed the side of the bulb (where the ground should be coming out) and there was a good 20 milliamps coming out of it, and there indeed is a closed circuit happening here! I don't understand this???? I have an 1156 bulb in, that is the correct bulb is it not? |
