Old 04-09-2006, 10:53 AM   #1
player11
Fog light question
My fog lights have been out for a while..probably a dumb question (but I haven't even examined them for cause of problem)..but is there a bulb for these? If not, would the fog lights be toast after just 4 years..or is it probably a wire or connection problem?. I did check the fuse under the hood and it was OK.
player11 is offline   Reply With Quote
Old 04-09-2006, 12:26 PM   #2
rodeo02
Re: Fog light question
One of the connectors on mine melted within a year. It appeared to be seated/sealed properly, but being mounted vertially it got water and dirt/salt in there and eventually shorted out. You remove the lamp holders from behind. Unclip the metal bails and the holders pop out.
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
rodeo02 is offline   Reply With Quote
Old 04-09-2006, 04:36 PM   #3
player11
I was able to take the bulb assembly out. There are wires connected directly to the bulb, so the bulb itself, I don't think can just be replaced. I unplugged from the Rodeo and now I'm holding an 8 inch piece with connection to Rodeo on one end and the bulb connected to a white wire on the other end. Can this be bought somewhere?..or do they expect you to buy another set of fog lights?
Old 04-09-2006, 06:00 PM   #4
msikdm
msikdm's Avatar
hi,
just replaced my fog light bulb with some help from this board... great
bunch of folks!
The bulb itself can be replaced. I have thrown away the package but
i believe it was an H3 bulb 5o watt? Oh i have a 98 rodeo... dont'
if they (fog lamps) differ from year to year.
good luck
msikdm
msikdm is offline   Reply With Quote
Old 04-09-2006, 06:02 PM   #5
msikdm
msikdm's Avatar
fyi
h**p://www.rallylights.com/hella/H3.asp
msikdm
Old 04-09-2006, 07:52 PM   #6
Canucklehead
Send a message via MSN to Canucklehead
It looks like this, right?
That's an H3 bulb (as msikdm pointed out). The base of the bulb should be held in with some sort of spring clamp. Disconnect the spade connection, unclip the bulb and put a new one in. It will only go in one way since the base has one round indentation and one squarish one.
Also remember DO NOT TOUCH THE NEW BULB WITH YOUR FINGERS.
2000 VW New Beetle TDI
2007 Honda CR-V
Canucklehead is offline   Reply With Quote
