Register FAQ Social Groups
Old 07-08-2002, 07:04 PM
poweredbyhonda604 poweredbyhonda604 is offline
Primer, Clearcoat do i REALLY NEED IT?
Just wondering if i a primer and a clearcoat are essential in painting my body...
Also, what is the difference between a laquerer and a clearcoat?
Thanx
Life begins at 8500rpm!
Old 07-08-2002, 07:12 PM
daggerlee's Avatar
First off, you should definitely read the FAQ posted at the top of the boards. But to answer your questions, primer is a must for a good paint job, and clear coats aren't necessary unless you want to use one.
Dan
Old 07-09-2002, 12:19 AM
hirofkd's Avatar
hirofkd hirofkd is offline
Unless color is dark, such as black or dark blue, plastic is somewhat translucent, and primer is recommended to block the light from passing through.
A body, prepared with primer have a solid feeling, eliminating cheap toy-like look, when compared to unprimed body.
Also, primer helps you find scratches and manufacturing imperfections such as sink marks or deformation due to heat. Plus, primer will help paint grab the surface.
Clear coat is optional, if the body color is solid, but it's highly recommended on metallic. Clear coat will create rich and deep wet look, just like a real car. (Real car is clear coated, of course.)
Lacquer is a type of a solvent, and the term is often used to categorize the type of paint.
Lacquer base acrylics, water base acrylics and enamel are common for hobby use, and each has pros and cons.
Hiroaki Fukuda
Old 07-09-2002, 02:33 AM
hrmodeler's Avatar
hrmodeler hrmodeler is offline
Send a message via ICQ to hrmodeler Send a message via MSN to hrmodeler
And you need clear coat if you make cars with lots of decals, like race cars. Clear coat will cover it and edges will not be visible and will look more realistic.
Zeljko Segin
http://www.hrmodeler.com - Fast wheels - my pages
My current project - .....
Old 07-09-2002, 04:02 AM
thanks for all the information. I did read the AF FAQ but wanted more info. on the subject.
