Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 02-17-2006, 06:11 PM
treezy23beastmode treezy23beastmode is offline
Exclamation 1993 Crown Victoria LX
I'm having problems with the lights flickering on and off when i press the brake and use the turn signals. I've tried changing the fuses and checking for shortages in the light switch itself... What could it possibly be?????????????????????
Old 02-18-2006, 01:26 AM
Loekee75's Avatar
Loekee75 Loekee75 is offline
Send a message via Yahoo to Loekee75
Re: 1993 Crown Victoria LX
Are you saying your brake lights are flickering when you have them applied?
http://www.cardomain.com/ride/2653398
1992 Buick Park Avenue (Daily driver)
2001 Saturn SL1 (gas saver)
Old 02-19-2006, 03:39 PM
Yes!!! I believe it may be either a spliced wire or pinched, maybe something is grounding off when i apply the brake because the sensor under the brake pedal feeds the power to the lights and the only thing i can think is that there is a malfunctional wire somewhere in the lighting diagram... I was told to run a relay from the light switch to the lights and back to the fuse box a see if i detect any flaws.
