Go Back   Automotive Forums .com Car Chat > Chevrolet > S-10
Old 01-18-2006, 04:06 PM   #1
trippinfong
Send a message via AIM to trippinfong Send a message via Yahoo to trippinfong
1991 2.5 4cyl with a miss
I have a 1991 S10 with the 2.5 with 108,000 miles. The problem I am having is that when the temperature outside is cold the engine will miss if I give it more than half throttle and the service engine soon light will come on for about 30 seconds then go away. When it's warm outside the engine runs great with no miss. I put plugs and wires on it about 4 months and and I just put a new distributor cap and rotor button on but that was no help. Any suggestions would be appreciated.
trippinfong is offline   Reply With Quote
Old 01-18-2006, 06:10 PM   #2
RahX
Re: 1991 2.5 4cyl with a miss
what kind of plugs?
RahX is offline   Reply With Quote
Old 01-19-2006, 11:48 AM   #3
trippinfong
It has autolite plugs in it......I'm thinking it's an oxygen sensor but I dont know.
Old 01-19-2006, 11:51 AM   #4
jonsonton
jonsonton's Avatar
The first thing I would suggest is to find out what code you are getting.
jonsonton is offline   Reply With Quote
Old 01-19-2006, 03:21 PM   #5
RahX
an o2 sensor wouldnt cause something like that based on temp. it sounds like a connection problem somewhere. go to autozone and have them check the codes when the truck is acting up. you have to drive it and DONT shut it off when you get there after it has acted up. let the guy pull the code with the truck running, or at least, dont turn the key off.
Old 01-19-2006, 07:25 PM   #6
trippinfong
Changed the oxygen sensor and it fixed it.
