Go Back   Automotive Forums .com Car Chat > Ford > Explorer | Explorer Sport Trac
Old 01-11-2006, 03:47 PM   #1
jharber15
Running lean and they want to charge a fortune!
I just had my car checked out due to the check engine light coming on. They said that I am running lean, and it is not my 02 sensor that is bad. THey said that this could almost be anything, and it takes extensive troubleshooting. They said they could troubleshoot at 95 dollars an hour, but it could take hours to find the problem. Then they will fix the problem. Obviously, this is a very expensive repair. I told them to hold off.
Do i have any alternatives? I was considering trading this guy in, but I would hate to lose money due to this, but don't want to throw money in a sinkhole on this troubleshooting.
What do you guys think?
by the way, this is a mom and pop shop charging 95 bucks an hour, not procare, or any of those types of places.
jharber15 is offline   Reply With Quote
Old 01-11-2006, 07:12 PM   #2
way2old
TOKEN HILLBILLY
way2old's Avatar
Re: Running lean and they want to charge a fortune!
what is the code numbers? P0171, P0174?
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
way2old is offline   Reply With Quote
Old 01-11-2006, 09:41 PM   #3
jharber15
Re: Re: Running lean and they want to charge a fortune!
Yes, I believe those are the two codes. I'll need to check my bill in order to be positive. I do not have it with me right now.
Old 01-12-2006, 01:25 PM   #4
Mike406
Some things to check for codes P171,P174
Check the PVC hose for pin holes, cracks etc. If that doen't work then
clean the very thin wires on the MAP sensor.
Mike406 is offline   Reply With Quote
Old 01-13-2006, 05:27 AM   #5
RahX
what year and engine? i know the newer 4.0s have a problem with the plenum o-rings getting hard and not sealing which sets off that pesky lean code. theyre not too hard to replace.
RahX is offline   Reply With Quote
Old 01-15-2006, 10:14 AM   #6
mab6680
please post on what you find i am having this same problem and cant find the cause
mab6680 is offline   Reply With Quote
