Old 12-06-2005, 06:45 PM   #1
rdwr01
1998 Lumnia LTZ Coolant leak
1998 Lumnia LTZ has been losing small amount of coolant about 2 months, Now I am getting a lot of steam and dripping from tailpipes. Is this a sure sign of head gasket? Also the motor wants to seize after it is shut off and has to cool before starting.
rdwr01 is offline   Reply With Quote
Old 12-07-2005, 09:48 PM   #2
corning_d3
Send a message via Yahoo to corning_d3
Re: Coolant leak
It's not a sure sign, but a good sign. Just remember, steam is normal when cold. The best way to test it is with an Exhaust Gas Analyzer. Just stick the sensor in the radiator while is warm and running. If it senses exhaust, you gotta bad head gasket. Just a quick question..has the car ever been overheated before? Aluminum heads really hate heat and will warp/crack easily..
corning_d3 is offline   Reply With Quote
Old 12-08-2005, 03:09 PM   #3
wafrederick
Banned
Does it have a 3.8 or 3.1 in it?If it is the 3.8 series II,upper intake.It is made out of plastic and cracks around the EGR valve port area.It takes in the water next and if you do not get it taken care of in time,car will not start.It fills the lower intake full of water.I have seen this so many times to the point all the spark plugs have to be removed,engine turned over to get the remaining water out of the cylinders and the plugs replaced.Suck out the water out of the lower intake with a wet/dry shop vac.
wafrederick is offline   Reply With Quote
Old 12-12-2005, 11:07 AM   #4
rdwr01
Re: Coolant leak
Thanks, I think that is what it is. It is a 3.8 and a mechanic said it was probably the intake since it is plastic. I had never heard of that, but I have it in the shop and they are replacing it.
Old 12-12-2005, 04:34 PM   #5
fastlq1
Re: Coolant leak
Do it ASAP. Coolant doesn't compress like air, and if you draw in too much coolant, you will have bent rods/broken pistons on your hands. I heard of a guy with a Quad-4 Grand Am with a cold air intake that was too low. He went through a deep mud puddle right after getting the engine rebuilt. Cost him a rod that bent and 2 new pistons.
91 Lumina Z34 5 speed swap (autos in these cars suck behind the DOHC)
92 Lumina Z34 5 speed (91 ZR1 Vette brake swap, sig pic)
95 T-bird 4.6l of pure crap
00 Daewoo Leganza (wifes new car)
fastlq1 is offline   Reply With Quote
