Old 12-08-2005, 04:38 PM
cjschade cjschade is offline
Angry No HOT heat and fan roaring
Just replace core and radiator; flushed and changed from orange to green antifreeze. No gurgling now, and some heat...measures 132 deg. F on digital thermometern while idling. Temp. guage never gets above 165 degrees. Replace 195 deg. T-stat to no avail. Mechanic now thinks there could be seepage around T-stat or engine runs rich causing it to run at lower temp.
Fan has intermittent 'roaring' ...up and down... continously...with heat control switch OFF.
Any suggestions as to how to get the Temp. guage to the 195 setting; and how to get more heat?
Old 12-08-2005, 04:44 PM
Re: No HOT heat and fan roaring
Any one ever experience this before?
Originally Posted by cjschade
I just replaced my core and radiator; flushed and changed from orange to green antifreeze. No gurgling now, and some heat...measures 132 deg. F on digital thermometer while idling. Dashboard Temp. guage never gets above 165 degrees. Replace 195 deg. T-stat to no avail. Mechanic now thinks there could be seepage around T-stat or engine runs rich causing it to run at lower temp.
Old 12-08-2005, 04:57 PM
Jeremy Fitch Jeremy Fitch is offline
Send a message via Yahoo to Jeremy Fitch
Bad fan clutch, kicking on too soon, causing engine to run cool?
Old 12-08-2005, 05:11 PM
Re: Re: No HOT heat and fan roaring
That sounds like it, but the dealers never agreed with that suggestion when I mentioned it to them.
Last couple summers we noticed the fan 'roaring' during the summer months when first pulling out with cold engine...it actually scared the wife.....as she thought the engine was going to blow up. Back then the dealer said it was normal in the summer as the engine needed extra cooling. He explained that the fan clutch has oil in it...and that when it got hot it spins more?
Another mechanic offered to replace the fan clutch, but we passed on it when we decided to replace the heater core and radiator...etc.
I'll look into the fan clutch scenerio you described. Thanks
Old 12-08-2005, 05:41 PM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Re: Re: Re: No HOT heat and fan roaring
Remove the clutchfan from the waterpully and let warm up to operating temp. If you get up to 195 you found the problem. Replace with an e-fan
95 s10 Blazer, EGR Mod, ZQ8 Steering box mod, 99 Center console shifter mod and more... See everything at www.pghconsulting.net/teal
Old 12-08-2005, 05:47 PM
makes sense. Any reason why the clutch fan will 'roar' sporatically like that?
I have an S-10...same engine...that I'm going to switch the t-stat with...just in case the new t-stat is defective.
What is e-fan?
Old 12-08-2005, 05:53 PM
rlith's Avatar
What is e-fan?
The reason it roars is that the clutch is worn out and not disengaging properly.
And e-fan means electric fan. Alot of us run those to eliminate the roaring, get slightly better gas miledge, more controlable, takes the weight off the front of the engine. Neatens up the engine compartment.
Old 12-09-2005, 07:45 AM
Rick1488 Rick1488 is offline
I have a brand new fan clutch and it roars when I first start the vehicle, but once I drive for about a minute it goes quite.
Old 12-09-2005, 07:50 AM
rlith's Avatar
That's normal because the viscous fluid is still cold and engages the clutch... His problem is that it's constant.
Old 12-09-2005, 08:56 AM
Well, we got blasted here in Pittsburgh with a foot of snow last night, so I couldn't do any work on the Blazer. I'll work on it this weekend, and post again as soon as I learn anything new.
Thanks
Old 12-09-2005, 09:58 AM
rlith's Avatar
Thanks
LOL a foot?? Only got 3 inches here...(North hills)... Though I'm glad all is well with my truck at this point, my garage is too filled to put it inside, only enough room for the wrangler...Need to drive out to RIDC today though, not looking forward to it... Too many morons don't know how to drive.
Old 12-09-2005, 10:18 AM
Lucky you! I shoveled at 9pm last night, and again at 7 am this morning. Crafton / Ingram area.
