Old 12-06-2004, 11:06 AM   #1
HAYEZ
car keeps dieing losing power?please help
1997 cavaler with 4 cyl 55,000 miles
what could be wrong with my car?when i start it it starts up,then i go to take off and the car loses electric and the lights and dash and everything starts blinking going off and on etc...the radio is reset everything,it takes about 4 or 5 times to get it to stay running,,it turns over perfect everytime and starts but then it just seems like it has some kind of electrical problem and shuts the car off and loses all electric in the car ,then i have to switch the key to off and the power comes back on when i try again,anyone know what the problem could be?
HAYEZ is offline   Reply With Quote
Old 12-01-2005, 12:28 AM   #2
roth_k
roth_k's Avatar
Re: car keeps dieing losing power?please help
I am having the same problem with my 2003 Cavalier... I also just recently noticed that when I turn the key off (and even take keys out!!)the gauges click on and off every few seconds... I'll let you know if I find a fix...
roth_k is offline   Reply With Quote
Old 12-01-2005, 12:50 AM   #3
corning_d3
Send a message via Yahoo to corning_d3
Without being there to test it, i'd guess the PCM is bad. I've heard a lot of the same complaints on cavillacs.
corning_d3 is offline   Reply With Quote
Old 12-01-2005, 03:11 AM   #4
roth_k
roth_k's Avatar
Re: Re: car keeps dieing losing power?please help
I'll do some research, but what exactly is a PCM and how much/how would I go about testing something like that? I have noticed that if I mess with the positive cable to the battery, I can get it to start and run, but I can tell the second something is not right. While engine is running, anything I do electrically has an effect on the power to the car, it almost seems like there is little or no battery power at all. But a few times, it idles just fine and seems perfectly fine, but when I turn off the car and try to restart it, I get one of 4 results...
1) Nothing at all. No interior lights, no cranking, no clicking, nothing...
2) Car will try to turn over but ends up just clicking. I'm assuming that this is caused by the battery being drained therefore not enough power to start from the gauges clicking off and on (which as I mentioned above, I just tonight noticed)... I have disconnected the positive cable for the night to save battery, and will check it out in the morning.
3) If i mess with it (positive cable connection) I can see when the interior light comes on brighter and I go in and all interior lights/gauges turn on as normal, but as soon as I turn key, *CLICK* and it seems power is lost and I'm back at #1 on my list of results.
4) Same result as #3, but the car starts right up just fine (until I turn off the car and try to start it again).
I will try messing with the connections some more in tomorrow and see if I'm able to narrow it down some more.
Old 12-01-2005, 12:22 PM   #5
roth_k
roth_k's Avatar
Talking Re: Re: Re: car keeps dieing losing power?please help
Well, I think I've figured it out, or at least narrowed it down a whole bunch. Went out this morning and re-hooked up the positive cable and it was still real touchy.
*Note* I kept driver side door open to watch for interior light to go on and stay on bright, that was the sign I had a good connection.
Still had the same hit and miss results, and just for kicks, I tightened the negative a bit more, and just barely tightening it did the trick for now. I'm not having problems with the gauges clicking on and off like they were before, so we'll see how long it lasts. If I don't post anymore consider the negative/ground the problem.
Hope this helps!
Old 12-02-2005, 12:39 AM   #6
corning_d3
Might be time for some new battery cable ends...
Old 12-02-2005, 02:16 AM   #7
roth_k
roth_k's Avatar
Well, it held up all day today with ZERO problems, but I'll know the first place to look if it happens again.
I'm just really happy that all I found that out before I replaced the alternator or anything else. Sometimes the simplest things are the problem.
Old 12-02-2005, 02:24 AM   #8
corning_d3
yup, and alternators are expensive...
Old 12-08-2005, 12:14 PM   #9
inatalonIXLR8
Good clean conections are a must. If there's any corrotion at all use baking soda in water to clean it up. Replace positive and negative cables plus conections off the battery and swab on lots of petroliem jelly to stop more corroding should clear up any future problems.
95 Talon Tsi AWD 5spd
2.4L4G64 6bolt JE8.5EagleTorqueplatedFully ballanced-balanceshaftARP Ferrea1mm 1Ghead ported/polished HKS264/272 fidanzagears turbonetics copy polished GT3076R VbandTial38mm cometic prothane mounts SARD850 stage4 Compclutch+flywheel 3"exh Walbro255 rewired Innovate wideband O2 ForgeBOV Autronic standalone innovative wideband[url=http://img494.imageshack.us/my.php?image=talonandhelicopter5as.jpg]
inatalonIXLR8 is offline   Reply With Quote
