Fan does not come on
I have a 96 Lumina 3.1 engine. My fan does not come on at all. I used to be able to get the driver side on by turning on the a/c, but that has stopped also. Temp gage works, fans work, relays work. When I disconnect the temp sensor both fans come on. I'm afraid that the computer is bad. I really don't want to spend $60/hr for somebody to tell me they don't know. Any ideas or steps I can do to confirm or discount the computer?
Lactose the Intolerant
![]() Join Date: Aug 2004
Re: Fan does not come on
I think in the absence of a relevant coolant temp signal, it defaults to run both fans just in case...so the ECM is probably working OK.
Check the harness grounds to the engine, I think they are at one of the tranny bellhousing bolts up top. You didn't have tranny work done or something where wiring mighta got forgotten or something, did you? I'll think about this some more and see if I can come up with a shadetree way to verify what's happening. When you turn the A/C on, does the compressor run? If the system is low on charge, the compressor won't run. No compressor, no aux fan, they are linked together.
Oh, and BTW are you overheating? How high if so?
#4 | ||
Re: Re: Fan does not come on
, I can control the temp to average a touch less than 50%.No recent transmission work. The a/c compressor does come on. |
hmmm. Sounds like the fan circuit lost a ground to me...
Wait...no..because you said they come on when you unplug the cts. Damn.
#7 | ||
#8 | |
Re: Re: Re: Fan does not come on
Any more Ideas??
#9 | ||
Did you consider you have two temp sensors, one for the ECM and one for the gauge? Maybe the other one is bad??
#10 | |
Re: Re: Re: Re: Fan does not come on
1. I was trying to figure that out, because (I guess) the temp sensor the Chilton's manual shows seems to only deal with the gage.
2. Where would it be located? 3. How could I test it? Thanks! |
#11 | |
I had the exact same problem on my 95. In fact, I ended up replacing the engine because of overheating. Its the temp sensor. Mine fans didn't work unless you unpluged it and my temp gauge worked fine. Cheap part. Should fix the prob.
#12 | |
I was in a parking lot for 45 mins yesterday trying to find a parking place so i could go inside and work... luckily i left early. my engine started getting right near the red, and i freak out when it gets anywhere near that... so i throw it in nuetral and give her about 2k rpms just so its quiet enough and brings it down. but i want to rig the fans on a switch so i can turn them on when i want.i have a 3 way switch, which i would make it work like this, Middle is off, Bottom is one fan, Top is both fans. i know electronics and im sure that is simple... can i just splice into that wire to make it work?
#13 | ||
