Old 11-11-2005, 07:41 PM
floaterboy floaterboy is offline
Send a message via AIM to floaterboy Send a message via Yahoo to floaterboy
Angry Need Help Finding Short!!!!!
I have an '85 K-20 350 4 Speed. The battery will not stay charged longer than 2 days. A battery load test reveals the battery is good. When I test for voltage from the positive side of the battery to the positive cable (after removing it from the battery) I get a reading of 13+ volts. I have removed each fuse and performed the above test with the same results, 13+ volts. Are there any other tests that I can try?
Floater
Old 11-12-2005, 03:37 AM
oregon712 oregon712 is offline
Re: Need Help Finding Short!!!!!
your dome lights could possibly be on, or the light under the hood, or lights on the sunvisor(if equipped). my parents 74 chevy have the same problem, the hood light was constently on and killing the battery. couldn't figure it out until one night we noticed light comming from under the hood. -oregon712
Old 11-14-2005, 02:39 AM
383stroker_1 383stroker_1 is offline
Is you altenator good? Your alt. will drain the battery fast. Your battery will still show higher volts as long as there is still juice there. You may want to have your alt. tested. Any auto parts store should help you with that.
