Go Back   Automotive Forums .com Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 11-18-2005, 06:48 PM   #1
d12shtonu
96 PLYMOUTH neon problemS
well i know that neons tend to have weak transmissions and i tend to have a lead foot and uhhh well yeah here's what i messed up
1: speedometer
2: automatic transmission
3: overheats easily (i didnt do that)
4: very slow cold start (wasnt me either)
I was accelerating one day and then all of a sudden the speedometer droped to 0 every now and then it'll work fine til i get up to about 50 or 60 or so then it drops to 0
as for the transmission when i accellerate slowely it will often vibrate violently and when i change into second it will grind every now and then as well if i push the petal all the way down though it doesn't do it at all
BUT when i have the petal all the way down all the time it makes it overheat easily causing me to break down in THE MIDDLE OF THE DAMN ROAD doing the embarrassing walk of shame pushing it to somewhere safe till it cools down then it works fine again
I also usually have to wait 20 or so seconds for it to start after it's been sitting for a few hours i think it has something to do with the fuel pump idk
Well i guess it's not that bad of a deal considering i payed like 500 for it and it get's me to work and everything but i was planning on making it a lil faster but idk if it's worth all the money now if anyone knows any enexpensive ways to fix my problems i'd love to hear them
d12shtonu is offline   Reply With Quote
Old 11-19-2005, 10:49 AM   #2
das2123
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Re: 96 PLYMOUTH neon problemS
No, actually the neon transmission is very strong and reliable if taken care of correctly.
Read this post and maybe search next time...
http://www.automotiveforums.com/vbul...d.php?t=480855
Manually shifting an auto tranny is a bad thing. You probably messed up the tranny by doing that. The tranny is reliable if you take care of it, meaning checking fluids, keeping the bands adjusted, and making sure you are adding the correct fluid, which should only be Mopar ATF+3 or 4.
You can buy a used neon tranny for around $300 or since you mentioned making it faster, I would suggest swapping in a manual transmission. All the parts can be bought for around $500. That will make you neon quicker to start off with.
das2123 is offline   Reply With Quote
Old 11-20-2005, 12:12 AM   #3
d12shtonu
Re: Re: 96 PLYMOUTH neon problemS
woud i have to goto the junkyard to get it for 500 or is there somewere i can get it newer
Old 11-20-2005, 10:35 AM   #4
das2123
Re: Re: Re: 96 PLYMOUTH neon problemS
Yep, or you can try www.neons.org and look in the For Sale-Parts forum.
