![]() Join Date: Oct 2005
240sx Lsd
Im going to be starting my project car pretty soon, and im curious to know how hard it is to upgrade the diff to a LSD and what the price range is
the car will be 1991 S13 `thanks |
Banned
![]() Join Date: Jun 2003
Re: 240sx Lsd
800-1100 for any LSD worth having.
or you could get the No Slip Differential for free if you have a friend with a welder. Its simple enough... your supposed to shim the carrier so it fits perfect but most people dont and it works problem free. |
Re: 240sx Lsd
why dont all people just weld up the differential then? I have many types of welders at work, but i wouldnt know what to do? You got any links or could you explain?
1988 conquest TSI -Lots of mods, finally finished WOOT!! ![]() Horsepower sells cars, Torque wins races! |
#4 | ||
Banned
Re: Re: 240sx Lsd
B) It will make the car understeer entering corners and generally feel really weird compared to LSDs. This doesnt matter on drift cars becuase if your entering far enough back you wont have entry understeer. C) People that dont know what they're talking about say you'll break axles, which is false. I know at least 10 people with welded diff 240s that have never had problems. The only way to break axles with a welded diff is HUGE tire and Horsepower, which will break things reguardless. You can however snap the welds, which is usually due to crappy welding. for about 200$ bucks you can get the "weld locked" diff from some guy in cali which is bullet proof... some guy apparently ran it without any gear oil and it was still going strong. I'll be getting a welded diff after I break in my new motor and get most of the kinks sorted out. |
#5 | ||
Re: Re: Re: 240sx Lsd
![]() Join Date: Jun 2004
hahahah LOL NO GEAR OIL WOW. i would have bet money you couldnt do that.
![]() "I got that hustle in my genes like high blood pressure" -E-40 |
#7 | |
Re: Re: 240sx Lsd
well, my car isnt going to be doing any drifting or drag stripping. purely a street car, i dont need something amazing but the thought of not having one isnt boding well. any thing cheaper then 800 or the no slip welded diff?
#8 | |
Banned
Re: 240sx Lsd
Theres the VLSD... and street use is pretty much all its good for. One of my friends used a VLSD for drifting, he ended up replaceing it three times in one year. Some people have shimmed them for more locking power but I don't know how.
You could get a VLSD for free to 400$ |
#9 | |
![]() Join Date: Sep 2004
Re: 240sx Lsd
well if there's no drifting or dragging... im sure a lsd isn't a top priority...
1993 RMS13 5MT KA |
#10 | |
![]() Join Date: Jun 2005
Re: 240sx Lsd
quaife sounds good for u then
its not quite an "lsd" but it should be good for the streets and any kinda performance stuff a little pricy though ($1500)
"I wish there was a knob on the TV to turn up intellegence. There's a knob called "brightness," but it doesn't work." -Gallagher still need a car...so sad
#11 | ||||
Banned
There are the Driveablity problems, like push in the corners and the car will fight itself at low speeds. But I have seen plenty of track cars with Spools and Weldeds (Roadrace) and its something you have to adjust to. Quote:
It was for one Drift Day sooner or later yeah, Of coarse, thats an easier way to get a diff to seize than welding it. But the R200 will put up with a shit ton of abuse, some drifters in japan pack scrap metal into a VLSD for increased locking, the Casing and Output shafts deal with 400+ HP Clutch Kicks regular basis and wont put up a fight. |
#12 | ||
That thing got a Hemi?
Re: Re: 240sx Lsd
a quaife diff is an lsd, however its different to "conventional" diffs, it is mechanical and not a clutch plate-type diff. unless you put massive, an i mean massive amounts of power through it you'll probably never have to replace it. so it'd probably end up saving you money in the long run.
Seatbelts Saved My Life
#13 | |
Re: 240sx Lsd
get a S15 LSD dude..300 $ or so, u need the out-put shaft dough...
VLSD is bad dude, ur engagement will suffer due to a slow and not complete transfer of power to the out side wheel, hence poor exit speed, and slow reaction to throttle, if any. Welled LSD ... come on... u don't have $$ don't fix up cars... get a LSD.. 2 ,1.5, quaify even VLSD! 2cts
"A good driver is measured not by his lap times, but by the amount of time he spend trying to make sense of his car" E.K. |
#14 | ||
Banned
Re: Re: 240sx Lsd
When did I say the R200 was Special? I'm just saying it isnt a Piece of shit like the S2000 diff or the R180. How many times do you want to tell me about gear whine from a inproperly shimmed diff? I know whats supposed to happen and I know plenty of people that dont have any problem with whine when they just use the shims off the old diff. Everyone needs to quit acting like Weldeds are the scorge of the earth. For Drag Racing and Drifting they work as well or better than a Clutch type that costs 1100. Yeah... if you do a shitty job on the welds it will break... just like anyother peice on the car. For road Racing or street, yeah, maybe it wont be your style... but there are plenty of people that track welded diffs, and 100% locking Clutch types. |
#15 | |
![]() Join Date: May 2004
Re: 240sx Lsd
If your car will be for street or grip style racing Quaife is for you. As it never locks up the diff, instead it gives the torque to the wheel with traction, therefore imposible to do donuts and drifts. It is safer though for everyday driving as you will most likely never get your tail end lose.
It is pretty much like having a traction control unit for practically any car without the complex electronics, and best of all ther is never need for overhaul. Although a lot of Porsche people use it for their racecars, so you know it is a very well developed diff. for most of your needs. I personally would save up and get myself that, as I am much more into grip then drifting, although sliding around is fun, I get much more pleasure out of being on the edge of your car's ability. Although it is much more dangerous as the speeds are higher, thats where my fun is at.
VR6> Anything FWD sucks for understeer? Swaybars do magic. |
