Go Back   Automotive Forums .com Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Old 10-19-2005, 10:16 PM   #1
GEOFFINKSTER
Thumbs down no horse power
bought a 94 stang with a 3.8L it only has 48,000 km on it . car has no horse power , rebuilt the engine and installed custom dual exhaust bbk 56 mm b-body , super chip , under drives , bbk cold air kit . with a g-tech only has 92hp . no change from when i first bought the car. Car has a/t with a stage II shift kit . with a scaner there is no codes, engine runs great but has soon as you crack the throttle it gasps for air , very poor throttle response. All injectors work , fuel pressure is 36psi , base timing is 22 deg, Ford said the car has 190HP.
GEOFFINKSTER is offline   Reply With Quote
Old 10-21-2005, 07:13 PM   #2
camaroincal
Send a message via Yahoo to camaroincal
Re: no horse power
Aren't 94 Stang 3.8's rated around 150 hp?
camaroincal is offline   Reply With Quote
Old 10-21-2005, 10:17 PM   #3
Kathmandu
My '95 is rated at 150hp from the factory according to my owner's manual and my Hayes manual. Once I put on Cobra style rims and tires I imagine my gear ratios changed enough to drop 20 hp from the final drive.
I would say the 3.8 is about as tuned as its going to get from the factory. I would have spent the money and got a 60's model 302 and dropped it in if I wanted a hot car.
Kathmandu is offline   Reply With Quote
Old 10-22-2005, 09:52 PM   #4
navajo50
Re: no horse power
base timing factory should be 10 degrees btdc . you can make it about 12 degrees and they will gain you some i think 22 would cause loss because of detonatin .{valve ping} try cleaning your injectors with a iv bottle that may help.
navajo50 is offline   Reply With Quote
Old 10-22-2005, 10:01 PM   #5
zx2srdotnet
Banned
zx2srdotnet's Avatar
Send a message via AIM to zx2srdotnet
Re: no horse power
92hp? holy hell my escort made 116hp
a typical stock manual 94-98 3.8 should be around 123
zx2srdotnet is offline   Reply With Quote
