2001 Buick Regal LS electrical problem.
I have '98 Century, a '01 Regal and a '08 Lucerne. Love 'em all!
The '01 Regal has lost power to the cig lighter and assessory power jack. The E5 fuse in the I/P block is good. There is power going into the orange wire at the fuse block but it isn't coming out at the connector in the center console. It looks like I will have to pull the carpet to get at the wiring harness. How is the carpet installed? Is it possible to get it out and back in neatly. Thanks, This is a great forum! IHS, Ted Leber |
AF Moderator Elite
![]() Join Date: Feb 2005
Re: 2001 Buick Regal LS electrical problem.
Do you have a good ground on the lighter/accessory socket?
Knowledge can be communicated, but not wisdom! ![]() ![]() |
![]() Join Date: Jan 2005
How far did you dismantle the console to determine you need to remove carpeting? Last time I checked you can see the wiring harness and electrical connector that feeds the 12 volts and ground to both receptacles as long as the door is open and ashtray removed as a cursory inspection.
#4 | ||
I used a needle probe on my DVM to penetrate the wire nsulation where it disappears under the carpet. No voltage there. I'm losing it between there and the fuse block. I need to get under the carpet but I don't want to mess it up. IHS Ted Leber |
#5 | ||
IHS Ted Leber |
IMO most likely at or towards the dashboard (right) fuse block assembly since that has been a known issue for some Regal and Grand Prix "W" body car owners. I recall corrosion issues or wiring directly at the fuse block.
Note: Until that is fixed I believe you will be missing 12 volts to the ALDL odb-ii port so a typical odb-ii scanner will not work if it needs to power off the port.
'08 Pontiac Grand Prix GXP (Dark Slate Metallic) - LS4 5.3L V8 '02 Oldsmobile Alero GL2 - LA1 3400 V6 '99 Buick Regal LS - L36 Series II 3800 V6 '03 Honda CR250R MX - 2 Stroke 250cc '97 Pontiac Grand Prix GTP - L67 Series II 3800 V6 Supercharged (Sold) Timeslip 08/12/06 AF Community Guidelines Last edited by BNaylor; 08-21-2008 at 07:18 PM. |
