Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 09-24-2004, 10:42 PM
mrtwo mrtwo is offline
Angry Help: Rear suspension weird noise?
I have been dealing with this weird noise for some time. I can hear the noise sounds like two pieces of heavy metal hitting each other. It sounds from the right rear area. It happens more often when speed is low say 30 mph on rough road. On highway, it does not happen as often.
I sent my car to my mechanics. He changed rear struts, right strut mount, right stabilizer bar link. And checked stabilizer bar bushings. A lot of labor has been spent but the noise is still there. Anyone know what it can be?
Old 09-24-2004, 11:13 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: Help: Rear suspension weird noise?
Does it make the noise occasionally or repeatedly and fast on a rough road?
Old 09-24-2004, 11:21 PM
It is hard to describe. Sometimes, it is occasionally. Sometimes, it is repeatedly, e.g. before a red light where the road is rough due to all the braking during hot weather.
Old 09-25-2004, 12:08 AM
nipsirc nipsirc is offline
It is your brakes. Must be the drums or the calipers are hitting metal.
Old 09-25-2004, 12:12 AM
Brian R.'s Avatar
Resident Chemist
Get as far under the car as possible - both sides - and have someone hefty bounce the suspension up and down while you try to locate the area or specific part making the noise.
Old 09-25-2004, 12:15 AM
Brian R.'s Avatar
Resident Chemist
Check your muffler/exhaust pipe hangers also.
Old 09-25-2004, 12:18 AM
Re: Re: Help: Rear suspension weird noise?
Thanks. But first I will sit in the car to hear if there is noise. I can not hear anything when I press the rear bumper up and down.
Old 09-25-2004, 12:19 AM
It happens no matter I use brake or not
Old 09-25-2004, 01:00 AM
Brian R.'s Avatar
Resident Chemist
Could it be something in your trunk?
Old 09-25-2004, 05:02 AM
I think it is possible. We may have looked at the wrong place. My rear brake is drum. What metal can it hit?
Old 09-25-2004, 05:08 AM
Congratulations to be a fanatic Before this a mechanic took all the stuff out the trunk and suggested me to change struts and mounts. There is water under my spare tire so I am going to take all stuff out and try again. BTW is that mean my trunk is leaking and the waste can enter the cabin?
Old 09-25-2004, 08:28 AM
Brian R.'s Avatar
Resident Chemist
Hard to say from my perspective. Nothing should get in your trunk. Probably a seal problem on the lid.
Old 09-25-2004, 10:33 AM
Mike Gerber Mike Gerber is offline
AF -Advisor
mrtwo,
When the mechanic took everything out of your trunk, did that include the jack and the jack handle? If not, make sure the are securely tightened.
Mike
Old 09-25-2004, 03:12 PM
This morning I took everything out to drain the water and took a test drive and the noise is still there.
I also noticed it will make one big noise when it runs over a large pit. It makes repeated but smaller noise on slightly rough road particularly on concrete road (the road looks pretty smooth though and i was driving at around 15 mph). There is no noise on really smooth road.
I also made a small bump and drive over it one wheel after another I was able to tell the noise is from the rear. Also the noise is louder from right side. I also feel the noise is louder when driving forward than backward.
My mechanics said something might have happened every time when the tire runs over a bump and is pushed up.
I probably should have stopped from the beginning but now I just can not stop.
Old 09-25-2004, 03:48 PM
tanuong tanuong is offline
You have to buy an aftermarket strut because the same happened to me.
