Old 10-10-2005, 12:05 PM   #1
CAPT703
cost to replace bag ignition switch
I was just quoted a cost to have the following replaced at my GM dealer
1). Replacing bag ignition switch
2). Replacing drivers door hinge pins and bushings ( quoted $100.00 )
total cost is $432.35
I live in CT if that makes any difference on how the cost is determined
thanks
Stephen
CAPT703 is offline   Reply With Quote
Old 10-10-2005, 01:12 PM   #2
mike2004tct
mike2004tct's Avatar
Re: cost to replace bag ignition switch
thanks
Stephen
Had my switch replaced last year. It cost $125.00 for the part from a GM dealer, plus 2 hours labor and 1 hour diagnostics @ $60.00/hour (discount thru the company I work for).
I just bought a new switch at Autozone last week for $89.00 (The same exact unit that Chevy sells). It took me 1.5 hours to replace it.
mike2004tct is offline   Reply With Quote
Old 10-10-2005, 01:56 PM   #3
Gabe25
Gabe25's Avatar
I replaced my 96 Blazer Ingnition Switch. Paid $76.00 from Redline Auto Parts (Which is Delco Parts). Took me about 1 1/2 hours to replace. Its really not that hard to replace. The only problem I can think of that you mite run into is the 2 screws that hold the Ignition Switch to the Ingnition key assembly. I had Male Torx screws holding it in place. Luckly I have a set of Male & Female Torx sockets. The rest of the replacement of the harness is easy.
1994 1st.Gen. S10 Blazer Tahoe
Aloha
Gabe
My Fleet
Gabe25 is offline   Reply With Quote
Old 10-10-2005, 03:28 PM   #4
mike2004tct
Re: Re: cost to replace bag ignition switch
E4 Torx socket, lisle makes a long shank socket specifically for GM/Cadilac distributor/coil removal. Also needed an E6 socket to get the top sterring wheel cover off, put a needle nose pliers will work.
Old 10-10-2005, 05:42 PM   #5
DINO55
DINO55's Avatar
CAPT703
I just replaced the hinge pins/bushings on both my front doors. Cost me...$20.00.
We have a sticky on how to do this yourself.
1998 BLAZER LS Vin-W 4Dr 2wd
2004 Cavalier LS 4Dr 2.2 Ecotec
"Good Part's ain't Cheap--Cheap Parts ain't Good"
DINO55 is offline   Reply With Quote
