Go Back   Automotive Forums .com Car Chat > Jeep > Cherokee
Old 08-13-2005, 04:26 PM   #1
Kedthompson
Information needed on the two fans 1999 JGC
g d
Our JGC has started to blow warm when sitting at a traffic light. We added some 134A, but it continues to do the same thing. It even blows foggy sometimes. I spoke with a friend who says the fan clutch may be bad, so I buy a new Hayden fan clutch. When I went to put it on I then discovered that the 99 has TWO fans, one belt driven and one electric and they're both between the engine and the radiator. I remember the friend saying that when the engine is up to temp. that I should be able to hear the fan clutch come in with a big whoosh sound. I've never heard that familiar whoosh with this vehicle at all, electric nor clutch. Should I go ahead and put the new clutch on and also a new electric fan relay, or take it to the A/C shop? I love this vehicle.
Kedthompson is offline   Reply With Quote
Old 08-13-2005, 04:49 PM   #2
GregA
GregA's Avatar
Re: Information needed on the two fans 1999 JGC
Is the air COLD when driving normally? If so, you probably have no worries.
Fog (or mist) seem to happen mostly in VERY humid areas (like Florida).
BUT ... you could have the A/C Drain plugged or partly blocked. Do you "hear" any water moving around under the dash? That would be another indicator.
As for the fans, as long as the coolant temperature gauge is "normal" (210 mark plus or minus 10 degrees), they should be working fine.
BUT ... Check that the electric fan is coming on when the A/C is turned on.
Take Care,
Greg A.
2001 Chevy Venture w/some "enhancements" ~ 105K Miles (Dec. 2010)
1992 Jeep Cherokee Laredo, 4.0L, Automatic ~ 155K Miles (Dec 2010)
GregA is offline   Reply With Quote
Old 08-13-2005, 04:53 PM   #3
Mistyeyez
Send a message via AIM to Mistyeyez Send a message via MSN to Mistyeyez Send a message via Yahoo to Mistyeyez
help please where is cam shaft posion sencer on 97 g-charakee 4.0 six
Mistyeyez is offline   Reply With Quote
Old 08-13-2005, 05:00 PM   #4
Mistyeyez
Angry help on 97 jeep
help on 97jeep
Old 08-13-2005, 05:11 PM   #5
Mistyeyez
help /////////
Old 08-13-2005, 05:45 PM   #6
Mistyeyez
hjelp
