Go Back   Automotive Forums Car Chat > Ford > Windstar
Old 07-27-2005, 08:59 PM
bjweening bjweening is offline
Fuel Filter
Hello, I'm new to the forum, and looking for some advice on how to change the fuel filter on my 2000 Windstar. I'm reasonably good at general maintenance, but have little experience. Any advice would be greatly appreciated.
Thanks
Old 07-27-2005, 11:42 PM
wiswind wiswind is offline
Re: Fuel Filter
I have a '96 windstar, so mine is different in some respects than yours.
My fuel filter is located under the car.....in front of the rear, driver side wheel... It is on the inside face of the frame member.
One end of my filter has a "duck bill" plastic clip that you slide out to release the fuel line from the filter.
The other end of my filter requires a special tool...
The tool is a plastic sleeve that slides up inside a crome connector....to release the clips that are inside the connector.
The plastic sleeve tools come in a set of various sizes......for $5-$10. You can get them at most auto part stores. They are used for air conditioning connections also....so they are sometimes called as such.
My set had instructions to use the 3/8" size for the FORD 5/16" size fuel line.
Old 07-27-2005, 11:44 PM
Re: Fuel Filter
You will want to release the pressure in the fuel system before disconnecting any fuel lines. The fuel system will hold pressure for quite a while after the car is shut off. The fuel pressure release for my '96 3.8L is on the front of the crome fuel rail....just under the upper intake manifold. Looks like a tire pressure valve.....has a little black cap on it.
Old 07-28-2005, 08:11 AM
lewisnc100 lewisnc100 is offline
Re: Re: Fuel Filter
My 2000 didn't require any special tools, just blue clips on either end of the filter that you depress and slide the lines off.
1997 Pathfinder XE
Air Lift Air Bags, Warn Hubs
2000 Windstar SEL
