92-95 Civic Manifold On 4th Gen?
Hi,
I will be doing my MPFI swap soon. Is it possible to use a DX 92-95 intake manifold for the MPFI swap? They look almost the same. This is the one- http://cgi.ebay.com/ebaymotors/ws/eB...category=36474 Thanks
1990 Honda Civic LX 5 Speed 1.5 Liter SOHC K&N Cone Filter APC Short Shifter 1988 Honda Civic STD Hatch |
ive heard of this working but have no confirmation about it, though i heard it was on an ex.
Name: Scott Stable Of Cars I have Owned: 1991 Honda CRX 1990 Oldsmobile Cutlass Supreme 2003 Honda Accord 1998 Chrysler Concorde 2007 Honda Civic 1997 Toyota Camry 1995 Saturn SC2 1996 Ford Taurus 1991 GMC Sierra 2002 Daewoo Leganza 1999 Dodge Ram 2007 Honda CR-V 2003 BMW 325i |
Re: 92-95 Civic Manifold On 4th Gen?
Yes you can since they are both a D series motor but you will still need the 88-91 ecu and injectors from a si/ex oh and the injector resistor box. or you can use the 92-95 ecu and injectors and wire for obd1.
Re: Re: 92-95 Civic Manifold On 4th Gen?
What do you mean injectors? The 4 fuel injectors will need to be replaced? I cant use the ones that come with it? Thanks
The injectors that come with the 92-95 are Obd1. You can use them but you need a 92-95 ecu.
Does it just plug in the stock location of the 4th gen ECU? After that can I just I just do the MPFI swap like it says? ECU wiring and dizzy wirign will all be the same correct? Thanks
88-91 si's have peak and hold injectors that require the resistor box, 92-95 civic have saturated injectors which require no resistor box
u can find 4 a6 injectors and resistor box and use them with your 92-95 manifold it wont make a diff altho when your done with the swap you might have acouple connections or plugs that couldent be used but it will still work
2002 Acura TL Type S 1991 Honda Crx Si |
How much do you think 4 fuel injectors will cost me? Lets say I got them at Autozone or Discount Auto? Thanks
Hey if your doing a MPFI swap your gonna need a PM6 ECU....Guess what today is your lucky day. I am selling one from a 89 5speed for 55bucks shipped!!
Just do the obd1 swap i posted earlier no response. I did it it was super easy kind of. All you do is get the manifold all sensors and ecu. i got this all from a junkyard(ecu, sensors, and manifold for only $40.00)......
Search for the obd 1 conversion harness. Do that first. Then you can follow the steps in the mpfi swap guide the # of pins are the same but the connector is different. Follow the instructions but dont use the injector resistor box. Its very cheap and a 5gen dx is better than a 4gen ex. Only when pertaining to the manifold. I reccomend changing all gaskets and also giving it a good cleaning. . Hope this helps |
I have 5th gen manifolds on both of my cars. The only real difference is that the map sensor is on the TB instead of the firewall, so you have to either use that map sensor and lengthen the stock wires, or else plug up the hole and use the stock map. otherwise, mine work perfectly.
Remember: You can't spell Crap without APC! Classic SE-R GTi-R turbo setup 3" DP U12 modified ECU Hyperco GenII suspension Progress sway SAFC etc. etc. |
Alright thanks.
So just to clarify this. I will need a complete 5th gen intake manifold with all the sensors and injectors. I will also need the ECU and complete wiring harness OBD1. Will I still need the injector resistor box? If I convert to OBD1? Is this a good OBD0 to OBD1 swap site? http://www.knology.net/~jediklc/OBD0...BD1%20Swap.htm Is it cheaper doing it this way or should I jsut do the regular MPFI swap? Thanks
No need for the resistor box with obd1. It is cheaber to go whichever way the junkyard will sell the stuff the cheapest.
I am 99% sure you can use the OBD1 injectors w/ the OBD0 ECM (PM6) and just leave out the resistor box.
i have a 91 Civic DX with 3x as much money in it as what i paid for it i wish it was fast here is my website http://www.geocities.com/krustindumm/index.htm |
I think i may just go with the 88-91 SI manifold because it seems like its alot easier. And cheaper by the time I got done with it.
Anyways thanks guys.
