Go Back   Automotive Forums Car Chat > Pontiac > Grand AM
Old 02-27-2007, 11:45 PM
Retiredgunner Retiredgunner is offline
Code P0440
98 GA, 3.1 V6. Check engine light on, scanner says I have P0440 Evap System fault. Does any body have an idea?
Old 02-27-2007, 11:51 PM
Gir-_-'s Avatar
Gir-_- Gir-_- is offline
Send a message via AIM to Gir-_-
Re: Code P0440
check the gas cap?
04' Mazdaspeed Miata - GT2860 @ 10psi
99' GRAND AM SE V6H.O. 188whp - Sold
Old 02-27-2007, 11:54 PM
Re: Code P0440
I tighten the gas cap up just to make sure. Reset the Code and it returned.
Old 02-27-2007, 11:57 PM
mjtr21 mjtr21 is offline
Re: Code P0440
had that on my car also and replaced the gas cap which fixed my problem after about a week or so. if not that then check any vacuum lines.
Old 02-28-2007, 08:40 AM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Re: Code P0440
that is a small leak in your evap emissions system, and it could be many things.
The gas cap is the easiest to check and replace.
Thier is a rubber seal on the gas cap and if its dried out it might be the problem.
Also check the hose clamps down by the gas tank as they can become loose and leak air.
But here is a better discription of what it "could" be.
The GAS CAP code
1999 Grand Am SS 3.4 OHV
Old 03-01-2007, 02:11 PM
Re: Code P0440
Gas Cap fixed it, thanks for your help.
Old 03-01-2007, 08:07 PM
Re: Code P0440
No problem, glad it was an easy fix
