Old 11-28-2004, 01:08 PM   #1
DocShock
2000 Cavalier - Headlights out, clicking sound from dash fuse panel
I have a 2000 Cavalier and recently I noticed that my daytime lights and headlights were going out when switching the car into gear.
The dash shows that the lights are on when in park, but when you put it in gear there's a "click click click click click" sound from the fuse panel by the drivers side door, which is followed by the service light showing on the dash panel and the headlights/daytime lights going out
I had some wires and a relay replacef earlier in the week, but it started happening again the next day. I opened the fuse panel and gave the relay a light tap and the problem seemed to correct itself for a short time, but then occured again later.
Could the relay they replaced be bad or might there be short or something?
Thank you.
DocShock is offline   Reply With Quote
Old 11-29-2004, 01:55 AM   #2
mattcurry
%99 sure it's your multifunction switch. Seen that problem a thousand times through the shop.
mattcurry is offline   Reply With Quote
Old 01-01-2005, 06:33 AM   #3
jable
Re: 2000 Cavalier - Headlights out, clicking sound from dash fuse panel
I was having the same problem. One of my headlights was blown. Check them at all three levels, driving, low, and high.
jable is offline   Reply With Quote
Old 01-03-2005, 01:49 AM   #4
wiseguy01
wiseguy01's Avatar
Red face
just replace your drl relay and you will be fine or better to see if it is bad remove it. i have a 99 and i removed mine the little light in the dash just blinks and the service light is trying to tell u to change it.
wiseguy01 is offline   Reply With Quote
Old 01-03-2005, 01:53 AM   #5
wiseguy01
wiseguy01's Avatar
thats the little black box in the fuse panel
Old 01-04-2005, 01:29 AM   #6
z24 fanatic
Send a message via AIM to z24 fanatic
I own a 2000 z24 cavalier and i had the same problem with my headlights the problem turned out to be that the headlights were wrong for the car check your headlights and make sure they match what your car needs hope that helps.
z24 fanatic is offline   Reply With Quote
Old 06-20-2005, 01:39 PM   #7
CATSMASHER
WHERE CAN I FIND THE "MALFUNTION SWITCH" ON MY 2000 CAV.
THANKS.
CATSMASHER is offline   Reply With Quote
